cantdrv55's Avatar
What can be done to prevent rear sway bar bracket from cracking?
Can the bracket be strengthened by spot welding? Should I even be concerned about breakage? I'll be doing DEs next year and my goal is to keep the car totally stock. No plans to upgrade the suspension until I get more seat time.
Old 11-16-2005, 07:39 PM
randywebb's Avatar
4 letters, W E V O
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-16-2005, 08:09 PM
Wavey's Avatar
You can strengthen the way the bracket mounts to the tub; some weld a diagonal brace made of flat steel strap to triangulate it to the floor pan. But the next problem you're likely to encounter is the threaded nuts tearing out of the bracket itself. There are then "fixes" for that problem. I'm on my second round of repairs - original brackets tore away from the body, replaced with factory "upgraded" brackets. Those tore out so I got another pair of factory brackets and added the Smart Racing reinforecement kits (they use a long threaded tube instead of a nut, and add a 4th welded-in side which "boxes" the bracket. So far so good. BUT - had the new WEVO part been available I definitely would have used that!
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 11-17-2005, 03:55 AM
chrisp's Avatar
In your case, since your mount hasn't been compromised yet install the Smart Racing reinf. plates. They're cheap, well made and a good welder can probably install them in 2 hrs.
'83 SC
Old 11-17-2005, 05:24 AM
