3.2 engine serial numbers
Hey wondering if anyone knows where I can find out further information about my engine from the serial number?
Mine starts with 63F?
It's a '85 and I believe the F = '85 and I think the 63 is european possibly?
I'm trying to figure out if I have the higher compression european engine and further information about the all differences from the north american engines?
Old 02-19-2010, 07:31 PM
E Sully's Avatar
According to Wayne's book, which I recommend you get, it is an '85 R.o.W, 10.3:1 pistons, 231 hp as compared to U.S.A. 9.5:1, 207 hp.
Old 02-20-2010, 12:11 PM
muck-raker
kidrock's Avatar
Hey Feds, is the car ROW as well?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-20-2010, 01:00 PM
Hmmm, thats what I was hoping for (i think). I got wayne's 101 projects, but I haven't seen a listing for engine serial numbers in it, or is there another book?
Yes, I believe it is a ROW car, it has the high side marker lights and cloth seats and non north american lights. It came over from japan, so its either japan spec or from somewhere else and imported there.
I'm in the process of trying to determine exactly what spec it is? and what the differences are in terms of engine, suspension, lights, emissions control devices, others......
Old 02-20-2010, 05:17 PM
Hold on......too much bad info here....
You need the Pocket Tech Spec Books. 10th digit in chassis number... if "F"....signifies 1985. Correct.
Engine numbers run a different pattern. For 1985.... 8 digits
first digit.... 6 ( 6 cylinder engine).
second digit...3= Carrera ROW , 4= Carrera USA or Germany with cat option , 7= Turbo ROW/Canada.
third digit.... F ....1985
fourth thru eighth digit.... serial number.
The engine also shows a "type" number cast someplace else on it, usu on right side vertical fan post--->
930/20 = 911 Carrera ROW with the higher HP.
930/21 = 911 Carrera USA/Japan/ or Germany with cat option M298...lower HP
930/26 = 911 Carrera, Sweden, Switzerland and Australia
930/66= 930 Turbo , ROW and Canada
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-21-2010, 04:31 PM
Anyone know where the engine type number is stamped?
Old 02-21-2010, 08:07 PM
a.k.a. G-man
Geronimo '74's Avatar
at the base of the fan, right side, take a small flashlight to see better.
Old 02-21-2010, 10:18 PM
Hi guys , there is no number on my engine 3.2- its not removed its just never there??
How can this be?
Old 01-20-2015, 12:33 PM
Looks like it was rebuild withing warrenty of porsche? cause i found some OEM cases wich allso have no serial nr.. Can anybody comfirm it?
Old 01-21-2015, 06:05 AM
Hilbilly Deluxe
emcon5's Avatar
82 911SC Coupe
GTI Cup #43
Old 01-21-2015, 08:29 AM
Yes that is Pasha cloth
redstack's Avatar
what number is this then?
So what does this number mean? It's cast in the bottom of the case. You know where all the oil drips.
I know from the vin that it's a ROW 84 carrera
84 RoW, slicktop coupe, with Pascha baby!
08 GTS Cayenne
Old 01-21-2015, 02:56 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Casting number on the right side case. 5R match your vintage.
Who Will Live... Will See
Old 01-21-2015, 03:36 PM
