3.2 engine serial numbers
Hey wondering if anyone knows where I can find out further information about my engine from the serial number?
Mine starts with 63F? It's a '85 and I believe the F = '85 and I think the 63 is european possibly? ![]() I'm trying to figure out if I have the higher compression european engine and further information about the all differences from the north american engines? |
According to Wayne's book, which I recommend you get, it is an '85 R.o.W, 10.3:1 pistons, 231 hp as compared to U.S.A. 9.5:1, 207 hp.
muck-raker
Hey Feds, is the car ROW as well?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Hmmm, thats what I was hoping for (i think). I got wayne's 101 projects, but I haven't seen a listing for engine serial numbers in it, or is there another book?
Yes, I believe it is a ROW car, it has the high side marker lights and cloth seats and non north american lights. It came over from japan, so its either japan spec or from somewhere else and imported there. I'm in the process of trying to determine exactly what spec it is? and what the differences are in terms of engine, suspension, lights, emissions control devices, others...... Last edited by feds; 02-20-2010 at 05:19 PM.. |
Hold on......too much bad info here....
You need the Pocket Tech Spec Books. 10th digit in chassis number... if "F"....signifies 1985. Correct. Engine numbers run a different pattern. For 1985.... 8 digits first digit.... 6 ( 6 cylinder engine). second digit...3= Carrera ROW , 4= Carrera USA or Germany with cat option , 7= Turbo ROW/Canada. third digit.... F ....1985 fourth thru eighth digit.... serial number. The engine also shows a "type" number cast someplace else on it, usu on right side vertical fan post---> 930/20 = 911 Carrera ROW with the higher HP. 930/21 = 911 Carrera USA/Japan/ or Germany with cat option M298...lower HP 930/26 = 911 Carrera, Sweden, Switzerland and Australia 930/66= 930 Turbo , ROW and Canada
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Anyone know where the engine type number is stamped?
a.k.a. G-man
at the base of the fan, right side, take a small flashlight to see better.
Сидеть, ложь, Переворачиваться |
Hi guys , there is no number on my engine 3.2- its not removed its just never there??
How can this be? |
Looks like it was rebuild withing warrenty of porsche? cause i found some OEM cases wich allso have no serial nr.. Can anybody comfirm it?
Hilbilly Deluxe
Yes that is Pasha cloth
what number is this then?
![]() So what does this number mean? It's cast in the bottom of the case. You know where all the oil drips. I know from the vin that it's a ROW 84 carrera
84 RoW, slicktop coupe, with Pascha baby! 08 GTS Cayenne |
83 911 Production Cab #10
Casting number on the right side case. 5R match your vintage.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
