Part number help 85 3.2
Hi Gang!
Just completed the long anticipated engine drop on the 85, and completed disassembly for paint over the winter. I need a couple of part numbers from the gurus: 1. Boot that goes through the body at the front of the transmission- not the boot over the linkage- the one that seals the nose of the trans to the body. 2. The gaskets for under the heated washer nozzles. 3. Gasket behind the center rear reflector. Thanks for the help!
Mackskibum aka Dave Austin '66 911 Work In Progress (#303734) '85 911 Carrera 06 325XI '05 Envoy XL SLT |
Schleprock
Re: Part number help 85 3.2
Kevin L '86 Carrera "Larry" |
Thanks KTL!
Anybody know if the older style non-heated nozzle is the same gasket? Those nozzles are 1/2 the price-if I have to buy the assembly.
Don't know for sure but try it...how much can it cost?
Or cut/shape new ones from inner tube.... ( ! ) - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Schleprock
I was thinking the same thing. Use the old gaskets as templates and find some decent material, like Wil's suggestion of inner tube rubber, to cut some new ones?
Thread Tools | |
Rate This Thread | |
