rev counter 3.0
Hi
we finished (well almost) the 3.0 conversion for my 911 T 1973. only the rev counter is not working anymore,,, common?
than ks!
Old 11-29-2005, 04:57 AM
Early_S_Man's Avatar
Porsche Crest
Did you check the Black/Violet wire at the back of the tach for pulses from the CDI 'TD' output terminal with an oscilloscope or CMOS logic probe?
The Black/Violet wire has to go through the 14-pin connector at the engine electrical [relay/fuse/CDI] panel ... a common problem area where corrosion can be found. Cleaning of the 14-pin connectors should be done very, very carefully, as the terminals are silver-plated brass ... no abrasives! Q-tips with 9% pickling vinegar, isopropyl alcohol ... are safe, followed by rinse with distilled water and air drying.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-29-2005, 10:31 AM
