project 911's Avatar
I ended up making one for mine but it was lots of work to get it right. I laminated three layers of clear acrylic sheet with bolts sandwiched between the layers. I bent it to the curve before cementing the layers. It has held up well, and if I want to change the look I can put the original reflector on. I've been tempted to make a mold from this.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 12-05-2005, 04:38 AM
"O"man(are we in trouble)
widgeon13's Avatar
Project 911
I'd buy one in a heartbeat.
Old 12-05-2005, 05:17 AM
Designer King
Paulporsche's Avatar
Steve B,
I'm assuming you sandwiched the bolts so they would not pull away from the plastic. Is this necessary? Would something like JB Weld hold them sufficiently?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-05-2005, 06:15 AM
Send a message via AIM to NoLift911
If this thing was made correctly with the right thickness some double sided tape would do just fine - it just sits there.
Porsche bolted this thing to the vehicle like it was going to be used to tow something...total overkill.
Steve das toight!!
Whoever wants to make a mold for this - mold away, I would surely buy one.
-Jeff
Jeff
Old 12-05-2005, 06:35 AM
Designer King
Jeff,
Why not just cut a strip of the appropriate thickness, paint it, and tape it on then? If you want the two built up squares @ the ends, just laminate a second piece of plastic there. Or, as I said earlier, if you have a white, black, silver, or (maybe) red car, you could apply a matching SA vinyl to the plastic strip new or existing).
Paul
Old 12-05-2005, 06:44 AM
Paul-
I have an illustration that shows how I put it together but can't get it to upload here. Use this link: http://www.deeplogic.net/911/panel.gif
The center layer has a hole or socket big enough for the bolt head to set in. I ground grooves in the bolt head so they wouldn't spin, and used epoxy to secure the head into the socket. The back layer has a hole just big enough for the bolt to run through. I cut all the panels a little long so they could be trimmed after it was done. I clamped all three layers with a curve that was close to the back of the car then used glue from a hobby shop to stick it all together. You just brush this liquid along the seams and it is drawn in by capillary action. When done I just sanded the edges smooth and painted it.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 12-05-2005, 06:52 AM
Don Cothard's Avatar
As I 've read this I found it somewhat funny that if we take the lettering of the back of the car no one would know what it is. The shape is a dead give away. I would also buy one in a second.
Don
Imagine Auto Stage 3
87 930
Big Reds
Coil over supension
HP alot (475+)
Torque even more (500 ft lb+)
ZLP ZLP is offline
Low Speed, High Drag
ZLP's Avatar
Same here, if someone wants to make this I will buy one.....
Old 12-05-2005, 07:26 AM
david.avery's Avatar
Thom, Thom, are you there? If he can make a hardtop, he can make this piece, and sell it pretty inexpensively I would think.
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 12-05-2005, 08:17 AM
Zeke's Avatar
Originally posted by dd74
I agree. Milt, how long would you need the part to make a mold?
For a splash mold with burlap and casting plaster, about an hour. That would be the best way, to make a better plug and then a perfect mold for parts. To take a production mold off the lense would take a couple of days of work and I can't work stratight through on that, so a week.
The plaster thing is probably a better wat to get started, but the aftermath to getting a production mold might be somewhat labor intensive and require a car for verification along the way.
Any way you slice it, it's definately doable. I've done many, many parts in my years, but have kinda sworn off the stuff (resins, gel coats, etc.) due to health reasons. Meaning, I'm a lot heathier as a result of not working with that stuff for the last 25 years.
But one more wouldn't hurt, I guess.
Old 12-05-2005, 10:46 AM
Mahler9th's Avatar
Make it out of cf
How about carbon fiber? You could use a single layer of twill. measure the original piece and cut a piece of cf twill just oversized. Then use some epoxy resin and press it between mylar to make a single thickness (and therefore flexible) piece that you can trim to fit over the original with scissors. I have experimented with single-layer pieces like the one you see on the fan strap. I put a decal on it and it is just taped to the metal fan strap.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 12-05-2005, 11:32 AM
hmm, seems like if you are just going to cover it up the vinyl tape (the kind they make for striping cars) would be the best bet. Anything thicker would be a step in the wrong direction. Seems like making a mold and making it from f/g would be pretty darn easy, but I've never done it myself so what do I know.
I bet if someone got Thom a date with a cute chick that didn't care about money he'd probably make you one for free.
Old 12-05-2005, 11:40 AM
drag racing the short bus
dd74's Avatar
This is exactly how my car would look, down to the color...
Okay, I'm definitely tempted -- even just to give it a try...
The Terror of Tiny Town
Old 12-05-2005, 01:08 PM
GT racing does not make these as an FYI...
Jeff
Old 12-06-2005, 09:24 AM
JBO JBO is offline
Isn't the reflector a safety item for rear visability? The rear lighting on these cars is not that great to begin with. Not sure I'd want to do away with the reflector for this reason, but I admit I'm getting old and no longer feel invincable!
Old 12-06-2005, 11:28 AM
I hear ya - however that reflector has the same reflective capability as a 1972 Huffy wheel spoke relector. Not much reflective technology there and what does get relected sits very low. Regular car headlights go right over it, if you are euro or lower ride height, forget about it.
I added a third high mount stop light to my 84 and run with DRL's
-Jeff
Jeff
Old 12-06-2005, 01:06 PM
I was thinking about the same thing today..If you build it I will buy...
Jay
2006 Dinan Cooper S sold
2000 Audi S4 sold
1979 911SC soon to be IROC clone
2007 Toyota FJ Cruiser
Old 12-06-2005, 04:49 PM
dweymer's Avatar
ok, maybe I will have to pull mine and mold it. I've got the glass, resin, even CF. How do I get it off? Mine is a '74, what years would it apply to? What would be a reasonable price for everyone?
Donnie
Currently Porsche-less.....
Old 12-06-2005, 05:02 PM
The best way to go with this is just to make sure the thickness is correct. Don't worry about attachment points. If the thickness is correct you can mount it with double sided tape and do away with the clips and bolts nonsense. So in other words account for say 1/8 thickness for double sided tape and go from there. As long as the panel is somewhat flexible it will bend to the contour of the rear.
The guy from GT racing was telling me that they had thought about making one but that is as far as they got. He suggested a piece of Lexan used for windshields/glass etc is the correct thickness. I think finishing a piece of plastic would be easier than the fiber/carbon deal.
-Jeff
Jeff
Old 12-07-2005, 06:12 AM
Designer King
Also, why do you need a mold for something that is a flat piece?
Paul
Old 12-07-2005, 07:42 AM
