-   -   The IF2 thread (http://forums.pelicanparts.com/porsche-911-technical-forum/254697-if2-thread.html)
PorscheGuy79 02-11-2006 07:27 AM
By the beard of Zeus!
You guys are nuts over there. That is an unbelievable set up.
beepbeep 02-11-2006 10:22 AM
OEM generator is a heavy b****rd and rubber belt that was powering fan and generator had hard time coping with torque whenever throttle was blipped and very heavy OEM rotor had to be spinned to speeds reaching 18000 RPM at highest engine revs. (we have 2> gearing on fan belt).
It's going to be replaced by much smaller one powered by geared down separate belt pulley with smaller diameter. That should make fan-belt last much longer than before.
http://www.itsfun.nu/if2_2006/1102/008.jpg
Front brakes which were OEM 930 brakes are finally being replaced for Big Red items. They were actually quite good but when opportunity to swap them appeared we couldn't pass it. Big Reds mean higher unsprung weight but also a bigger margins when it comes to repeated braking.
http://www.itsfun.nu/if2_2006/1102/009.jpg
beepbeep 02-11-2006 10:25 AM
Minor changes occured today. We had hard times packing everything into engine compartment so it was decided to chop of rear and replace it with a flip-front and tube chassis.
Mounting and dismounting engineand access to plumbing/spark plugs etc. was hard. This way we should be able to lift the rear skirt and have everything easily accessible.
http://www.itsfun.nu/if2_2006/1102/001.jpg
Tokan does what he does best: cutting cars.
(I always dreamed about doing this on a 356 :D :D )
http://www.itsfun.nu/if2_2006/1102/018.jpg
http://www.itsfun.nu/if2_2006/1102/022.jpg
http://www.itsfun.nu/if2_2006/1102/024.jpg
http://www.itsfun.nu/if2_2006/1102/033.jpg
beepbeep 02-11-2006 10:36 AM
Of course, that makes it somewhat hard to mount the engine the usual way but it was solved by fabricating new engine mount that was sandwiched between engine and gearbox. That way whole engine will hang from the back and everything is easily accessible. I think somebody did this before on 935 or something like that.
We also considered flipping the G50 transmission upside down (like they used to do on 935's) in order to gain better shaft geometry once the car gets lowered but it proved impossible as ring and pinion couldn't be reversed (and we didn't like the idea of 1 forward gear and 5 reverse gears). We gained slightly better geometry by raising front engine mount a bit.
http://www.itsfun.nu/if2_2006/1102/019.jpg
http://www.itsfun.nu/if2_2006/1102/081.jpg
Once roof is off, it was a great oportunity to strengthen the cage by redoing all welds with a TIG welder:
http://www.itsfun.nu/if2_2006/1102/083.jpg
Alternative engine mount points are needed so they are fabricated near rear bulkhead:
http://www.itsfun.nu/if2_2006/1102/086.jpg
http://www.itsfun.nu//if2_2006/1102/088.jpg
http://www.itsfun.nu//if2_2006/1102/087.jpg
beepbeep 02-11-2006 10:39 AM
Tadaaaa....
The final solution to changing spark plugs on 3.6 engine w/o removing heaps of stuff:
http://www.itsfun.nu//if2_2006/1102/080.jpg
It's gonna be much easier to do field-service now. It also saves heaps of weight. Hmm....car looks more and more 935-ish, but with 30 years modern technology.
RarlyL8 02-11-2006 09:16 PM
I'm simply ........ speachless.
You guys are beyond nuts. This is like Monster Garage - Porsche Edition.
Is anything going to support the rear of the engine?
BeauBlues 02-11-2006 09:42 PM
Note the key word here,..."Minor" changes. My head hurts from thinking what a Major change would be.http://www.pelicanparts.com/support/smileys/explode.gif
beepbeep 02-11-2006 11:57 PM
Well no, not really. We'll lengthen the cage into a spaceframe extending back around engine. It will provide pickup-points for removable CF rear skirt but majority of engine weight and torque will be transmitted by middle mount.
beepbeep 02-12-2006 09:23 AM
A little more was done today.
A beggining of home-made G50 shifter assy:
http://www.itsfun.nu/if2_2006/1202/12021.jpg
More cage pipes:
http://www.itsfun.nu/if2_2006/1202/120216.jpg
Front suspension pickup points are cut and are to be widened 7cm on each side of the car:
http://www.itsfun.nu/if2_2006/1202/120217.jpg
Björn installed turbochargers so clearing can be checked:
http://www.itsfun.nu/if2_2006/1202/12028.jpg
http://www.itsfun.nu/if2_2006/1202/120210.jpg
beepbeep 02-12-2006 09:24 AM
Small generator is installed on engine:
http://www.itsfun.nu/if2_2006/1202/120213.jpg
Intercoolers have to be parted a little to clear the fan:
http://www.itsfun.nu/if2_2006/1202/120212.jpg
http://www.itsfun.nu/if2_2006/1202/120215.jpg
Everyone is busy in garage:
http://www.itsfun.nu/if2_2006/1202/120219.jpg
Tokan feels the power between his legs:
http://www.itsfun.nu/if2_2006/1202/12022.jpg
This is how it should look like. Pretty 935-ish, in my opinion. Weight should be in the ballpark too.
http://www.itsfun.nu/if2_2006/1202/12024.jpg
PorscheGuy79 02-12-2006 09:35 AM
Goran, without the resistance of the large in fan alternator and having the fan over driven, is there any risk in over spinning the fan or the bearings it rides on (if it rides on any, I only imagine that it does)?
beepbeep 02-12-2006 09:43 AM
Yeah, no problem. Fan is going to spin on a bearing mounted in support that is going to be installed in the hole that OEM generator once lived in.
Whole "middle hole" is going to be blanked out so air can still move trough vanes just as it always did.
PorscheGuy79 02-12-2006 09:45 AM
I figured you guys were on top of it, I was just curious.
I like the writing on the rear flairs. :D
ChrisBennet 02-12-2006 09:47 AM
Sweet!
Not that anyone would go off the track backwards with a 911 ;) but have you considered running some sort of bump/nerf bar to protect the motor?
beepbeep writes
Thank you for your time,
Goran
No, thank you Goran for your time!
-Chris
beepbeep 02-12-2006 09:52 AM
Chris:
There is general agreement that we'll have some sort of pipe shield around the engine. There will be a rear engine mount as well but it won't take the brunt of weight and torque like it used to do but just make sure engine doesn't move longitudinally and provide hard points for CF cover.
Glasgow 911SC 02-12-2006 10:17 AM
Goran,
Any pics of this car when it was in standard form? Just as a baseline.
bolt 02-12-2006 10:36 AM
Holy MOLY! Great stuff. Thanks for sharing. Looking forward to seeing more...
beepbeep 02-12-2006 11:05 AM
Originally posted by Glasgow 911SC
Goran,
Naah, there is one pic in first post on it's thread. It was just a plain vanilla 930 with coilovers.
PorscheGuy79 02-12-2006 11:40 AM
Goran,
Is this a single owner car (maybe even your car) or does your shop own it? Is it just a toy or does it compete in any events?
beepbeep 02-12-2006 12:00 PM
Goran,
I'm just a hired gun in this project and are offering my help just for fun of it. This car started it's life as a show car and project is run by Jocke "Qvarnis" Qvarnström and his company "It's Fun" (which sell custom made tuning chips). I believe he is gradually inclined to get into some sort of organized track events with this car.
We are going to Nurburgring this spring and car is going to be driven in "Scuderia Hanseat" event to begin with. There are many sponsors involved, otherwise it would be very expensive to do this.
Bodywork is being done at X-Custom shop. X-Custom are leading Swedish custom shop and were featured in TV and also did some stuff for MTV Nordic. I'll ask guys if I can post few pics on some other cars they did. There is a particular Targa tub that got converted to "James Dean" Speedster with stunningly beautiful full-metal bodywork and suicide doors. They are very skillfull.
