Zombie
Spark Plug Replacement
Any tips for a newbie changing his spark plugs for the first time? ie) special tools/techniques
I've done this many times on my Honda Civic but the tight quarters and angle on the P-car is really freaking me out. ___________ Thanks T-RONE 87 911 COUPE |
The special spark plug tool that comes in the factory tool kit is invaluable. My '88 3.2 has no A/C and I can change all 6 plugs in about 10 minutes with this tool.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I also like the factory spark plug tool and I put a thin coat of anti-seize on the spark plug threads. Make sure you start the plugs with the tool and your hand, you can "feel" if the plug is threading straight. Then tighten and your set.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Slippery Slope Victim
The factory sparkplug tool is the best. If you do not have one then a good sparkplug socket wrapped in some duct tape so it does not disengage inside the head works well also.
I use a 10mm allen socket on a 3/8" ratchet instead of the factory 10mm allen wrench from the tool kit. Anti sieze is a must, (for the next time you remove the plugs. Very important....DO NOT OVER TORQUE the new plugs. Spin them in hand tight then just snug a little, Don't forget to tighten the little nipples on the top of the plugs if they are there. In general it's a very easy job as long as you can squeeze your hand past any obstructions. Good Luck
MikeČ 1985 M491 |
"just snug a little"
1/3 turn if you don't have a torque wrench
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Zombie
Thanks guys, the spark plug tool worked great! Also followed additional tips, turned out better than I thought.
Thanks Again T-RONE |
T-RONE,
The 'Klein 21' spark plug wrench and 10 mm Allen wrench that used to be included in the early factory tool kits is the best method ever devised for changing spark plugs on a 911 engine, and they are occasionally available on eBay as 'Mystery Porsche tool/wrench' ....
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
