Gauges in lieu of Radio ?
In "another" P-car catalog of a few years back... they showed a drop top 911...either a Targa or a Cab, from an overhead/behind view... clearly showing the ( then in vogue) white gauge faces for the instrument cluster... but also 3 gauges with white faces in a panel where the radio used to be.
Is such a gauge face available anymore...maybe from our host...or is this a home made device nowadays? What 3 gauges are used in that location? What gauge size? 2" ?
Wil
Old 12-28-2005, 05:39 PM
Jubbie's Avatar
On my 914, I pulled all of the HVAC stuff out since it is a fair weather hot rod. In the place of the ventilation controls, I placed Three VDO 2 1/16" gauges. I did volts, amps, and cyl head temp. I have the 904 tripple gauge for oil pressure, temperature, and gas tank level next to the tach. To put the gauges in where the ventilation controls were took some cutting. I used the metal plate for mounting the gauges under the dash to hold the guages in the hole. It turned out real nice.
I bet you could fabricate something for the 911 radio area. You could do the volts, amps, head temp, exhaust O2, transmission temperature in that spot if you wanted. Everyone has to find that point between "more data GOOD" and "Too much info"
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 12-28-2005, 07:44 PM
don911's Avatar
I did something similar with the switches from my center console. I first tried to modify one of the factory radio delete plates that pelican sells but it didn't workout.
I gutted my old stereo and just fabbed a face place out of thin wood and covered with vinyl.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 12-28-2005, 07:55 PM
Early_S_Man's Avatar
Porsche Crest
Wil,
I suspect that the panel was homebrew, then or now ... and I would suggest Voltmeter, Cylinder Head Temp., and Transmission Oil Temp.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-28-2005, 07:59 PM
Todd Simpson's Avatar
This is homebrew, made from thin sheetmetal.
Old 12-28-2005, 08:03 PM
All suggestions are very nice and duly noted....just wondered if the core panel was available from someone or homebrew. Looks like nominal 2 " gauges should work..can always check dimensions/ clearances myself.
Thanks folks...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-29-2005, 06:49 AM
Wil,
I seem to recall having seen something similar and recall vaguely that it was on a slant nose Turbo with lots of Sonderwunsche (Special Wishes) Department extras. I suppose that if you have the money anything is possible..................!
Ian
Old 12-29-2005, 07:51 AM
Wandered off somewhere...
Drdogface's Avatar
Wil,
Take a look here: www.nhspeedometer.com/perf_panels.htm
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 12-29-2005, 08:26 AM
Drdogface:
That's the ticket...
Only thing...the Carrera radio face plate dimensions are about 2 1/4" x 7 1/2". Might get by with a bit more if you're willing to hog out the "hole" left by the departing radio..and get into the "frame" dimensions somewhat. I'm also kind-of confused on the listed dimensions of the VDO gauge pack ...something looks weird.
Wil
Wil Ferch
Old 12-29-2005, 04:40 PM
I'm with Bill
Rick V's Avatar
Don I like the ac switch placement you have done. Very p-like
Old 12-29-2005, 05:28 PM
