tc-sacto's Avatar
Adjustable spring plate question
I did a search, but couldn't find the answer I was looking for.
Installed Sway-Away- Adjustable spring plates tonight and have a question for those of you who have these. The ride hight adjuster screw seems like it could move around easily. Does the load of the smaller piece of the spring plate onto this screw keep it from moving around?
Could one put a thin jam nut on the top section of the screw to keep the screw from moving from it's intended position?
I know that Haydon, of Wevo, addressed this issue with a set screw to hold the adjutsment screw in place.
99 supercharged Boxster
1977 911 race car - gts (sold)
Spec 911 Racing
Porsche Racing Club
Old 01-14-2006, 11:24 PM
Use a little bit of blue loctite if your worried. The other design bothers me because of the way the threads are being possible damaged with the set screw.
Old 01-15-2006, 02:49 AM
chrisp's Avatar
Loc-tite is a one time use product.
The ideal sdjustable springplate would not only answer the structural issues often related to the Weltmesiters but also have a cut in the adjuster screw body and a cinch bolt to hold/release the ride height adjuster screw.
'83 SC
Old 01-15-2006, 05:27 AM
paslantnose's Avatar
You can buy set screws that have a brass tip on them that will not damage the bolt threads.
1980 911SC Slant Nose
Can you say MegaSquirt !
Old 01-15-2006, 05:37 AM
Or you could put a dab of paint on the adjustment screw and check it after a week to see if it has moved. You might be be surprised to see that it hasn't moved at all and that all your worrying is for nothing.
Old 01-16-2006, 02:49 PM
efhughes3's Avatar
Sheez....I put anti-seize on mine as I was worried about the exact opposite.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-16-2006, 03:10 PM
For what its worth, I've had mine on for 5 years with thousands of track miles and they haven't moved.
Old 01-16-2006, 03:55 PM
abit off center
cgarr's Avatar
Me too, but if your worried just mark it with a dot of paint
______________________
Craig
G2Performance
Old 01-16-2006, 04:29 PM
Dave Nordhoff's Avatar
I just installed mine and I did add some 8/32" nylon tipped set screws. The 2"x1/2"20 set screws were sloppy so I measured them and they are .478 in diameter. I picked up some new ones and they are .496". No more slop. It probably doesn't matter but it bothered me they were loose.
Dave
Old 01-16-2006, 04:45 PM
tc-sacto's Avatar
Thanks for the input. I think I'll try the paint idea first. If they slip, i'll drill a whole and use a set screw.
Spec 911 Racing
Porsche Racing Club
Old 01-16-2006, 05:44 PM
+ lurking - contributing
Does the car's entire rear weight rest on the small square projections?
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-16-2006, 06:19 PM
