Fitting P201 to a generic engine stand
So the rotating mount on the P201 measures 57.5mm and the ID on the generic engine stand collar is 60mm.
For the most stable setup, I'd like to 'sleeve' the engine stand collar for the smaller shaft. What has anyone used? I've heard (thanks, Zeke!) that a strut body is an excellent sleeve -- but a strut that can be cut up is a rare bird... Any other solutions before I go shopping for a short piece of thinwall steel pipe?
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
I'm wondering if another type of material would be suitable/improve? Brass, PVC, monkey hide, etc.
It must stand up to the weight, but the rpm's are pretty low!
Mike B. '72 911E Coupe Early "S" #1065 |
For a wall thickness of 1mm, I think we can rule out the PVC, but how're you fixed for monkey hide? Come to think of it, the cheapest commodity in this town is spec movie scripts... I could probably use a couple scenes' worth of dialog to fill the gap...
Friend of Warren
Sounds like a lot of work for very little return. While there may be a bit of a gap (<3mm) I can't say as I ever noticed any stability problems.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I mounted my P201 to an inexpensive Harbor Freight engine stand, and it worked fine. I rotated the engine many times on the stand without problems.
Mike '80 911SC Weissach Edition '87 325is '02 K1200RS |
I understand it may not create issues, but I'm not good at ignoring the basic concept that I'm using a cheap stand to hold up a $300 engine mount and $2500 engine... I'm looking to create a better distribution of stress on the stand yoke.
Knock yourself out, but these things are made to be used with cast-iron V8 blocks that weigh much more than a 911 engine.
MBruns for President
cut up a milk carton (the plastic one gallon kind) and wrap that around the sleve then insert...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Thanks.
Crotchety Old Bastard
"Knock yourself out, but these things are made to be used with cast-iron V8 blocks that weigh much more than a 911 engine."
You'd be surprized. My fully dressed 930 engine in stock California smog trim wieghed a whopping 530 pounds! I was very afraid to move it around on the stand.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Autodidactic user
I rebuilt a Ford Cleveland 351 V8, rotating it MANY times, on a POS Northern Hydraulic engine stand without any problems. That engine weighed more than my mother-in-law!
I wouldn't worry about the 911 engine.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
I've got my 3.6 on exactly the proposed combination, currently. Actually, my stand is more than 10 years old. I never questioned that it wouldn't hold. It has been fine for a week. It didn't occur to me that I'm walking a tight rope. However, i don't think that I am. This feels stable.
I'll take a close look at the welds for cracks. Doug
1971 RSR - interpretation |
Senior Member
Bill,
I have one that I bought off of Pelican. A gent in San Diego made the "ring" and then mounted it to his HF engine stand. Worked very well with my 3.6. I have had a Jag engine on a HF engine stand but you could tell that it was straining. It weights a lot more than a 911 engine and is just plain a PITA to move around. If I were doing much work on a expensive 911 engine might do some re-enforcement welding on the stand. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I use the same unit as Danaskman....with a few mods.
I removed the center leg & welded up one on either side so's I could get a jack directly under there. Tain't pretty, but works slick.
JPIII Early Boxster |
The HF headquarters is a reasonable drive from here and they have a retail store in their (two square block) building. It's dangerous to go there... for tool shopahoilics like me.
attaching tens of hot air balloons to the motor could help reduce load..?
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
How about left over shims from some elephant racing poly bronze :-)) I have a bunch left over.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
