Help - RSR Clone Won't Start - No Fuel
I'm trying to run my RSR clone once each month over the winter. I started it the day after Christmas and took it for a nice run. No problems.
This week I can't get it started. I let the pump run for a minute or so, pump the gas 3 or 4 times. The engine tries to fire, but it will not sustain. I look at the sight glass on the PMO float bowls and see no signs of fuel in the bowls. As I move the throttle linkage, I see no signs of the fuel jet from the accelerator pump. When I disconnect the fuel line to the carbs and run the pump I get plenty of fuel flow from the pump. When I try to blow into the line leading to the carbs, I get no flow as if the float needle valves are closed. I don't have a lot of experience with carbs but it seems as if the bowls are empty and the needle valves are closed preventing fuel from entering the carbs on both sides of the engine. Any experienced help or suggestions will be appreciated.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Insert Tag Line HERE.....
Tom, if you could, post a picture of the fuel inlet side of the carbs. Its been awhile since ive been into PMOs, or Webers, but it seems odd that both sides of your carbs (left and right bank) are giving you the same problem. But the fuel inlet houses a needle-in-seat valve which is attached to the floats. As the floats rise up, -when the fuel bowls fill up with fuel-, then the needle closes the inlet off until the fuel is used, the level is dropped, and the cycle starts over again.
You can try tapping lightly on the inlets to break them free, as old gas can cause them to stick, and that might work, or you can simply take the inlets off and clean them out. Nothing will come "undone" by doing that. Let us know..
Marc |
Author of "101 Projects"
You probably pegged it - either someone put some small ball bearings in your fuel hose, or your needle valves are stuck closed from old fuel. Try tapping on the side of the carbs near the valves lightly with a plastic hammer...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I agree with Rattlesnake that it would be odd to have the same problem happen in both carbs. The car started and ran fine around Dec 26 and then sat for a month before I tried to start it again. Everything is brand new, fuel cell, fuel pump, lines , filters and PMO's. I hate to take the carbs apart.
However, unless the bowls are full, I should be able to blow into the inlet lines to the carbs. Am I correct on that assumption? I'll try to free up the needle valves as Wayne and Rattlesnake have suggested and will report back..
Re: Help - RSR Clone Won't Start - No Fuel
Dead head regulator designs can clog.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Well she's purring away in the garage as we speak warming up for a short run.
Disconnected the fuel line to the carbs tapped on both fuel rails with my rubber mallet. Then I blow through the inlet lines and I get through flow. Button the lines back on and exercise the throttle, and fuel spays from the accelerator pump. Car then starts on first try. So now the question...What would cause the needle valves to stick and how do I present it in the future? Thanks a million to Wayne and Rattlesnake.
rsr
Glad to hear you got her running.. I would think just some old fuel sitting.. when I am parking my 66 911, boat etc.. for extended periods I mix in sta bil and it seems to prevent sticky issues... not sure if its the "recommended" solution but it has worked for me..
david
David Brunson Sharpsburg, Ga 1966 #300720 sold |
Since I plan to take it out for a run once a month over the winter, I think I'll go with the fuel stabilizer.
BTW...Spent the last couple of hour chasing around the back roads here in CT. Boy do I love this car!!!
rsr
I probably missed them but do you have any pics.. dont forget the engine room.. thanks...
david
Here's some pics
Another RSR Clone Project - Before & After Another RSR Clone Project - Dyno Day Another RSR Clone Project-Track Day
rsr
Hi,
thanks, I remember your car now.. great shots. anxiously awaiting the spring thaw.. david
Gasoline nowadays doesn't seem to have a long shelf life, even with stabalizer added. EFI would cure sticky needle valves
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Yep that is what I mean.
Dean
I've never seen a stuck closed needle into the seat and I've seen plenty of gummed up carbs. Stuck open is another story.
whatever
Tom,
Did you have those wheels made?
1973 911T Sepia Brown MFI 1986 Carrera Meteor Gray Metallic |
