This object is stuffed under the right rear fender on my 86 930.. 2 Qs - 1. what is it?? ...and 2. how can I remove it ( is it just the one bolt that is exposed that I need to remove?) As you might be able to tell by the pic, as a winter project, I am in the process of undercoating the vehicle with POR15 and would like to remove this if not too difficult in order to get behind it properly. Of course, I will reattach it when finished. Just want to make sure I won't be asking for trouble.
Thanks ~ Jerry
86 930 Turbo Guards Red / Black |
I hope it's not ticking......kidding. Anyhow, not sure what that is, but it seems to have some type of air flow hoses? Just a guess.
Good luck,
Jon '85 Targa (recently acquired by Coollx) '02 Carrera 4S (holy moly...I'm in heaven....in the snow too) '06 BMW 325i (gone and forgotten) '03 Honda Odyssey (more dings every day....thanks wifey) |
I tlook slike the canister for the A/C system, the ones that holds the condensation. Then again it could be a charcoal canister for the smog.
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Not A/C-that's the dryer in the front LH fender. Something to do with smog probably, or some kind of relief valve for vacuum system?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
charcoal cannister.
just dont eat whats inside.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
follow the hose and see where they go
X/A |
Banned but not out, yet..
A black lab puppy? It can be easily removed with a small dog biscuit. (Since everyone is guessing... what the hike)
An air cooled refrigerator. ‘Mein Teil’ |
If John Walker says its a charcoal cannister, its a charcoal cannister.
AGREED ! If John Walker said it is. it IS
I removed it and it is very light, I am sure it as a charcoal canister.. it's all cleaned up now and ready to be returned to its original place Thanks all for the timely help Jer I'll post pix after I'm done
I don't know if John is right this time, I think RSBob is a little closer to the correct answer.
86 Carrera Targa - Garnet Red Metallic 88 928 S4 - Gran Prix White |
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
coolcavaracing.com
Hi Jerry, not wanting to change from the original subject, but could you give some more details about your project? I am going to do the same job this spring, and was wondering how to get round all the stuff under the front of the car. Did you remove it all to be able to get in there, or are you just putting the POR15 round it all?? Additionally, how did you remove all the old stuff first?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
911 carrera 3.2 (1985)
Hi Jerry,
I've done the project already. It's realy easy to remove the cannister. Just remove the bolt from the bracket (underneath the cannister). The bracket itself sits in place with two nuts. There might be a lot of dirt behind it, especially in the corner with the panel which holds the door striker plate. Before: New bracket: After: Kees.
Sorry, didn't see that you just figured it out.
Kees.
very clean work, kees.
ryan
Kroggers - I'm mechanically "challenged", so I removed only those things that I could easily remove. ( covers, spoiler attachments, etc...) and I'm painting the entire underside with a very small brush.. seems to be able to get to all the places I want to so far. I pulled the rockers and the rear bumper off also and cleaned up those areas as well. ... as far as the old stuff, I am just covering it after a thourough cleaning. 2 or 3 thin coats seems to be working nicely... I'm really happy with the way it looks.
coolcavaracing.com
Thank you for the info. I will probably work to remove the old stuff first, as I want to make sure there is no rust there before I put on the POR15...
