Jcon's Avatar
Question Brake Gurus - Input needed on 993 conversion
Thanks to the evil influence on this board (Bill V, JeremyD, KTL) I'm going forward with adding 993 calipers to my 3.6 SC. My wife says this is by far the most expensive free website ever created.
I've sourced the calipers/adapters and rotors. I had the holes in the rear calipers welded in and i'll be grinding those down this weekend and redrilling so I can send them off to be rebuilt and powdercoated.
Anyway - I need to order a 23 mm master cylinder.What one do I need. Is there one that will require less work to plumbing than another (Trying to avoid making new hardlines).
Thanks - This won't be the last question.
Jeff
Jeff C
76 912E 2.6L
Old 02-18-2006, 03:29 AM
Bill Verburg's Avatar
Turbo Master Cylinder, 911 (1978-89) #930-355-011-03-M4
On this page
Bill Verburg
Old 02-18-2006, 04:26 AM
Jcon's Avatar
Bill
As always - Thank you!
Jefff
Jeff C
76 912E 2.6L
Old 02-18-2006, 04:28 AM
I'm going down this same path. Is there anything else needed for this Master Cylinder swop in a boosted SC?
Thanks!
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 06-12-2006, 08:50 PM
Jcon's Avatar
Nope...It was a direct bolt in. Not a bad job either. It took me about 3 hours total.
Jeff
Jeff C
76 912E 2.6L
Old 06-13-2006, 03:30 AM
Blanco's Avatar
17" in rims for tt
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 06-13-2006, 03:56 AM
MBruns for President
JeremyD's Avatar
and remove your bias valve...
Old 06-13-2006, 05:59 AM
