Purpose of brown wire loop with connector near DME
I found this brown wire loop near the DME harness on my '87. It was not connected. What does it relate to? If it measures certain parameters and it's not connected would that screw-up my Steve Wong chip mapping because I'm sure Steve assumes it's connected, right? Some help appreciated, couldn't find this wire in the search.
Old 02-25-2006, 12:12 PM
MysticAlpaca's Avatar
Send a message via Yahoo to MysticAlpaca
That wire gets disconnected after an Steve Wong chip is installed. The SW Chip assumes that has been unplugged.
--bil
EDIT: Here is the link to the install instructions that have a detailed explanation as to what that wire does:
http://www.911chips.com/C1INSTR.pdf
87' Red Targa
10' Jeep Wrangler Unlimited
07' Subaru Impreza (lease ended)
02' Mini Cooper S (traded )
91' VW G60 Corrado (sold )
Old 02-25-2006, 12:17 PM
OK, so when it's time to smog check I should reconnect the brown wire to gain some margin in passing the test? (I don't want to remove the Steve Wong chip).
Old 02-25-2006, 12:32 PM
Good question. I think you want to leave it as is. The SW chip should be fine for smog checks. If you plug in the wire it will foul up the chip readings and could effect your test.
I havent tried smog yet with mine, anyone else here know?
Steve Wong may want to post here.
87' Red Targa
Old 02-25-2006, 01:55 PM
