KCinBR's Avatar
HELP -broken sway bar mount
I was piddling around under the P-car today and found my right rear sway bar mount broken, no wonder it handled a little funny.
1. What causes these to break?
2. Could I have done it by jacking it up?
3. what is the best way to fix this?
4. can this bracket be repaired ?
I do have a welder, wire feed, and some welding skills.
Here is a few pics looking at from the wheel well with wheel removed.:
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 02-25-2006, 01:46 PM
Very common problem, There are new, reinforced replacements available everywhere, including, I'm sure, our host. Might as well do both sides while you have you work clothes on.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 02-25-2006, 01:57 PM
Grady Clay's Avatar
Try this thread.
”right rear sway bar mount mysteriously torn from car”.
A Pelican Search will yield many more.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-25-2006, 03:26 PM
Make Bruins Great Again
Por_sha911's Avatar
You can weld them but I have been told that it is a temporary fix at best. When my left side broke I had it removed and a new reinforced factory mount welded on (do a search and you will find pics I posted). It is a simple and inexpensive job. The newer reinforced design should last close to forever.
Joe
Old 02-25-2006, 07:36 PM
Formerly bb80sc
Vipergrün's Avatar
May as well remove those and install the Weltmeister (or similar) mounts, which are pretty beefy
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 02-25-2006, 08:27 PM
Send a message via AIM to johncarlos2003
do it yourself- shops like to charge loot for it- if you weld, it's a a no brainer- just prep it right- search will do it- i think shops here in la want like 200 a side parts and labor- it's a nothing fix but don't be bummed- almost every carrera owner i know has repaired, cracked, or broken mounts-
john-carlos ynostroza
88 G50 coupe, black/black
Old 02-25-2006, 08:55 PM
Now that you've been driving without the benefit of the rear sway, let us know what difference in handling you notice after you get it fixed.
Cheers,
Joe
Old 02-26-2006, 07:18 AM
Just curious, now that you've been driving without the benefit of the rear sway, let us know what difference in handling you notice after you get it fixed.
Cheers,
Joe
Old 02-26-2006, 07:20 AM
Just yesterday I had the WEVO mounts welded on after my right rear mount sheared off. They are far sturdier than the factory replacement and (IMO) worth the few extra bucks.
Old 02-26-2006, 11:01 AM
How much do they Wevo mounts run for? I too have a broken sway bar mount.
Thanks,
Alex
orozcoa@earthlink.net
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 07-03-2006, 11:12 PM
lateapex911's Avatar
I think our host has them. They are the best choice by far.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 07-03-2006, 11:18 PM
3.4 Bigger is better
88-diamondblue's Avatar
Factory mounts, fixed twice PITA
Wevo mounts $89 each
Never to have to worry about them again.
Priceless!
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 07-03-2006, 11:47 PM
wheatdog's Avatar
Do It Yourself
If you've got a decent MIG, go with the smallest wire diameter available and corresponding lower amp setting. Don't get carried away trying to weld the section directly under the torque tube all at once, you'll burn through. Go a little at a time until you get some metal layed down. I did mine and they came out perfect even using fluxcore. If you've had much practice successfully welding to thin sheet metal, you'll be alright.
Mike
Old 07-04-2006, 03:36 AM
Jim Smolka's Avatar
Just remember to remove the DME brain box prior to welding on your car.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 07-04-2006, 05:06 AM
Thanks for everyone's feedback, I do have a small Craftsman fluxcore welder that I plan on doing the job with. Thanks for the additional tip on removing the DME just in case. I'll set my welder on Low and adjust the wire feed speed accordingly. I did a search on our host parts search and could not find these mounts. Does anyone suggest any specific word to try my search again?
Thanks,
Alex
Old 07-04-2006, 08:54 AM
Elephant racing has them.
Old 07-04-2006, 09:03 AM
Hmmmmm I THOUGHT I'd seen them here! Mght try calling. Or Elepant or Wevo.
Old 07-04-2006, 10:04 AM
Zeke's Avatar
Thanks,
Alex
Were you looking for WEVO, or OEM?
If you DIY, add some metal gussets or backing. Tyson Schmidt actually boxed them and reinforced them. With a little 3/16th steel scrap, a hacksaw and a grinder, you could do a lot for no $.
Search TS and sway bar mounts. There are some good pics. Of course, he works for WEVO now, so he won't say this is as good for a smaller bar and not full on racing. I think it is.
Old 07-04-2006, 10:11 AM
I had a friend weld mine in I made the mistake of buying Weltmeister - what crap. My friend looked at them and laughed he reinforced them and welded them to a larger pieceof metal and then welded them to the car. This was the second time it was done on the car and I didn't want to do it again
DJ 1986 911 Cab
1988 735i
Old 07-04-2006, 10:27 AM
