86 911's Avatar
Send a message via AIM to 86 911
Question Installing CA smog parts on a '78 Euro engine?
Okay, I just got back from the referee station to get my engine OK'ed for the CA smog exam, and it turns out I need a few parts:
1) EGR (Exhaust Gas Recirculation Valve)
2) Air Injection (line from distributor, air pump)
3) Gasoline Evaporator needs to be hooked up
How do I fabricate these into a Euro engine? Apparently a euro engine in a CA car is illegal, but the P.O. did it anyway
. How easy is this fabrication to do? Here's my current engine setup (Euro '78SC):
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 03-01-2006, 06:36 PM
RETIRED
Joe Bob's Avatar
Thinking longer on it.....the previous owner if it was sold in CA is responsible for smog certification and you should never buy a car w/o getting a smog certificate.
You would probably better off getting a smog legal motor than modifying this one AND be $$ ahead. Sell this one and get a compliant one in trade. Parts Heaven in the Bay Area may swap you one for a few bucks less than the conversion would cost......I'm surprised that a ref would send you off with a list of mods as opposed to failing you on visual inspection.....
2012 ML350 3.0 Turbo Diesel
Old 03-01-2006, 06:59 PM
Here's the air injection setup. I removed mine from my 1980 Euro SC, I think US 78-79 models have the same setup.
Here's a closeup of the injectors.
John Adams
1980 ROW 911SC
Old 03-01-2006, 07:05 PM
RETIRED
Joe Bob's Avatar
BTW....when I purchased MY euro 911 I was surprised to see that it had a smog pump. The US and CA 83s didn't have them.....my records showed that it had been Federalized TWICE....once in Texas and then again to a stricter standard in CA.
CA wouldn't allow me to remove the pump even though I was able to show that CA model 83s didn't have one.
Over the years I have run up against CARB/BAR and the smog stations and it's best to transfer complete motors as opposed to modifying an existing one....trust me you do one thing and take it back and they say...oh that won't work....best to get a documented complete motor and transfer THAT.....with ALL the intake and exhaust without ANY changes.
Once past the referee then you can screw around a bit.....that will be in lesson number 2.
Old 03-01-2006, 07:13 PM
86 911's Avatar
Wow, thats a lot of work! I thought it would be a small weekend project that would cost $200 tops! Trading it in as you all suggested would be a good idea (how about a 3.6 litre? ) Mike, don't you have a 3.6 in your cab.?
Matt
'71 VW Bus
Old 03-01-2006, 11:31 PM
450knotOffice's Avatar
Yea, but then you've got the problem with a 964 or 993 engine in a early car. California is not friendly to engine swaps. Do some research though.
Good luck Matt.
Old 03-01-2006, 11:43 PM
86 911's Avatar
BTW, is a 964 engine considered computerized? The pamplet I have says that if a computerized engine is installed in a non-computerized vehicle, the "check engine" light, OEM diagnostic link, and all sensors switches, and wiring harnesses needed to make the system functional must also be installed.
Matt
'71 VW Bus
Old 03-01-2006, 11:54 PM
RETIRED
Joe Bob's Avatar
Yes and yes....
My question is...why did you get sent to the referee?
Old 03-02-2006, 05:53 AM
Get ready for bending over!
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-02-2006, 07:28 AM
Matt-
How did you register your 911 in CA in the first place? The car would had to have been smogged. If you didn't get a "test only" smog notification then you may be able to fake it on some of this stuff. I took my 76 (which still has the 2.7) to a station in Lafayette and I had made a few appearance mods that made my engine pass the visual. The guy had to tweak things a bit on the rollers, but he got it to pass on the 3rd try.
Old 03-02-2006, 08:13 AM
1yearonLy's Avatar
Yes, the systems can be dummied up to look functional. If you get the right tester, they'll never know...
and it'll still pass if in good tune.
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 03-02-2006, 10:08 AM
vash's Avatar
i got MOST of the smog pump stuff. (as a matter of fact maybe 1yearonly, has the rest). stuff is off of a 75 car. i will sell it to you cheap. if it will work.
this sucks matt.
poof! gone
Old 03-02-2006, 10:28 AM
1yearonLy's Avatar
if it wasn't for the help I got through fellow Pelicans like Vash, I'd have never got through smog. Thanks!
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 03-02-2006, 11:33 AM
86 911's Avatar
Jon, the previous owner smogged the car before I bought it. I just looked at the recipts from a smog shop in San Ramon. They passed everything on the car, even parts that were not there at all (i.e. catalytic converter, EGR Valve and pretty much everything else that the referee failed upon visual inspection. We are about to call our lawyer and go after these guys. Can someone give me:
An estimate on converting (adding all the parts necesssary) to the Euro '78 engine to make it a legal CA '78 engine?
Matt
'71 VW Bus
Old 03-05-2006, 11:54 AM
RETIRED
Joe Bob's Avatar
You really can't.....that motor is not a CA approved motor. The best would be to put the CORRECT motor in it.
It's technically illegal to convert it unless it's done by a licensed Fedralizer and it in the SAME car that came from Europe.
Ask me how I know.
Mikez
Registered Environmental Assessor
County Air Pollution Control District
Resident Smog Weenie
PS...I don't know WHAT those morons thought they were getting away with when they did the engine change and sold in CA. That car won't pass as is in CA. Get the DMV investigative division involved as well....
Old 03-05-2006, 12:21 PM
