lally911's Avatar
Any difference in turbo trailing arms
A friend is looking to build an RSR on an SC body and has a line on some turbo trailing arms from a G50 car. is there any difference between trailing arms from a G50 car versus older turbo trailing arms?
Thanks.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 03-04-2006, 10:48 AM
Bill Verburg's Avatar
Re: Any difference in turbo trailing arms
Thanks.
'86/915 and '87/G50 arms are the same
Bill Verburg
Old 03-04-2006, 11:20 AM
I am sure that you know that the n/a and turbo arms and mounting points are very different
Bill Verburg
Old 03-04-2006, 11:22 AM
lally911's Avatar
No, I didn't know that Bill. The platform is an 81 Euro sc so it sounds like euro trailing arms will be required. I'd like to see some pictures of the difference in the mounting points if anyone has any. The roller is not yet available for inspection.
Keith Lally
Old 03-04-2006, 11:41 AM
Warren Hall Student
Bobboloo's Avatar
Just so you know. You don't have to use turbo trailing arms with a turbo body car. The SC arms with spacers will do fine. Depending on the offset of the wheels you choose spacers may not even be needed.
The turbo arms and mounts are a slightly different suspension geometry setup that may or may not be peferable to the owner of the car. Some of the suspension gurus like Tyson would be able to explain the advantage and dissadvantages of the turbo setup.
P.S. There is no difference between euro and usa arms.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 03-04-2006, 12:16 PM
lally911's Avatar
Got it now :-) NA for normally aspirated, and not North American.
Thanks for the help.
Keith Lally
Old 03-04-2006, 06:32 PM
Bruce Andersons Perfomance Book from 1995-96 explains it in detail. It provides for increased squat. The pick up points on torsion bar are different. The mounting for the caliper is behind and not in front of the hub as on the normal aspirated.
antares
fatnwide
Old 03-05-2006, 12:26 AM
