Fuchs polishing--how to remove spider webbing?
I've searched the boards and jewelers rouge and 4" buffing wheel was supposed to be 'da bomb' but that really seems to bring out a spider webbing/grainy finish out in the aluminum under my garage flourescent lights. Is there a final step after this to bring out the mirror finish? Thanks
1980 911SC Targa 3.6L |
Chances are that you didn't get the fine scratches out when you started buffing with the rouge. You can either use some tripoli (a final application that is a fine scratch remover), or some 1500 wet sand paper. Then hit it with the rouge. Mothers aluminum polish is also nice for a final finish. Don't be too hard on yourself. I've seen fuchs from a finisher that many use here and they had many fine scratches in them.
Thread Tools | |
Rate This Thread | |
