JeffO's Avatar
Need help with possible rear spoiler purchase
Please help me with this spoiler. I can not visualize this at all. Is it upside down? If so, how does it attach to the deck lid? Where does my air conditioning condenser go. Does it stay in the same place where it already is? Also it is said to be a porsche oem part. How would I verify this. Anything else I should know before I call the seller. Sorry about all the questions but I am not even sure what this is worth. Thanks for the help
"The smaller the fine print, the larger the risk."
1988 911 coupe
2008 VW R32
2004 530I
Old 03-10-2006, 03:52 PM
Bill Verburg's Avatar
That's a Carrera or RSA spoiler. It would look something like this installed
Bill Verburg
Old 03-10-2006, 04:02 PM
Used Up User
imcarthur's Avatar
You are looking at the top. If it is real it will have 'Porsche' on the underside middle. You must drill holes in your decklid to install. Your AC stays as is once installed. There are 2 metal brackets that mount on the inside where you drill the holes - one right & one left - so make sure that you get them. I'll look for a picture . . .
Ian
'87 Carrera Cab
Old 03-10-2006, 04:23 PM
Used Up User
imcarthur's Avatar
Here you go. The 'top' of the tail mounts in the existing grill bolt holes. For the bottom, you must drill 5 bolt holes in the lid. These are re-inforced by the brackets that you can see on this picture.
Ian
'87 Carrera Cab
Old 03-10-2006, 04:33 PM
JeffO's Avatar
Thanks to all of you. Great info, this board always amazes me.Bill, my coupe is silver also, excellant color for a 911. Thanks again.
PS; any idea on what it is worth?
1988 911 coupe
2008 VW R32
2004 530I
Old 03-10-2006, 05:53 PM
