front sway bar bushing replacement
I am replacing my whole ac system on my 82 911sc and noticed the rubber bushing on the front swaybar are deteriorated. the front suspension is unloaded . what surprises should I expect when I take off the sway bar to replace the bushings?
Old 03-13-2006, 06:12 PM
Oh Haha's Avatar
No surprises there.
Simply remove the old ones and replace with new.
might want to use a samll amount of grease so the new bushings slide on easier.
Pacific Blue
Wayne
Old 03-13-2006, 06:14 PM
coloradoporsche's Avatar
I had to loosen the A-arms to get the sway bar back in. Not a big deal...just a few bolts.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 03-13-2006, 08:09 PM
I 'Spanish windlass'd' the bar and it slipped right in without additional disassembly. Use a silicone lube for rubber bushings, (Dow DG4 or any di-electric). Petro grease may attack the rubber.
Old 03-13-2006, 08:59 PM
Banned
juanbenae's Avatar
i did it without loosening the a-arms. you just need to lub as noted above, get one side started and run it by as far as you can to get the other side into the keep on the AA. don't hook up the bar to the cross member until you have both sides in the aa 's and centered. it also helps to jack the car up so the AA's hang down a bit.
i did it with the bigger carrera sways to boot.
Old 03-14-2006, 08:39 AM
safe's Avatar
Jepp, lube and brute force did it for me too.
Magnus
Old 03-14-2006, 08:59 AM
Wildman Emeritus
I had to loosen theA arms on my '80. Just couldn't get the arm to slide in without pushing the rubber out of its keeper.
Worst job I've done to date & that includes exhaust stuff.
Finished the rear last weekend & it was a breeze.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 03-14-2006, 09:58 AM
Wow, I did mine with the car sitting on its tires in the garage. Got one side in [ I recall pushing the end in deeper then it would be when all said and done] and then worked the other side in without an issue. Both bushings where lube with silicone spray. It was a 20 minute job with most of the time used up R&R the plate...this was on a 78SC
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 03-14-2006, 10:09 AM
930yyc's Avatar
Looks like I'm going to be doing the same job...order parts and hoping it's as easy as it sounds/looks when the parts arrive.
Noticed most of the bushing missing...when starting a brake job.
Glad I noticed, probably would have not passed inspection at the track.
'86 911 Carrera ROW
Old 04-02-2006, 08:46 PM
safe's Avatar
I just did my sway bar again and this helped a lot!
It helped me to bend the bar enough to get in into the bushing.
Magnus
Old 04-02-2006, 10:25 PM
