Replacing door checks, help!
I am trying to replace the worn out original door checks on my SC. I am having trouble getting the original pin out. I have managed to tap it down to being flush with the tab sticking out of the frame, but I can't get it any further. I have tried a punch and hammer but there just isn't any room to get a good swing/hit on the punch. I tried using vise grips and wigggle it out, but this sucker doesn't want to go.
Any ideas would be greatly appreciated.
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported) ![]() |
Here is a pic. of my problem. The blue tape was my attempt on saving the paint from the hammer.
I wish I could offer some advice, but I am in the same boat as you. I couldn't get my pins to budge, so I moved on to the next project. I'm interested in a solution as well!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
heiliges blechle!
There was another thread on this a while back.
edit, I was mistaken, that was for the hinges. sorry
'84 M491 '07 Silverado '75 Suzuki GT550 2-stroke triple '02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train Last edited by Bill in OKC; 03-24-2006 at 07:47 AM.. |
Center punch and drill it out.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
Couldn't you adapt or fabricate a small press for this task? What if you notched a small C-clamp so it slips around the bottom portion and then gently presses the pin out?
Brian |
Autodidactic user
Go get a long solid metal dowel (18 inches or so) from Home Depot. You will be able to slide this down onto the pin with plenty of room above to get a good swing and not have window frame in the way. I got mine out using an old extra long phillips screwdriver. I ground down the tip until it was flat and used the same method as above; I just had the screwdriver laying around and didn't care if it got ruined (it was from one of those cheepo sets I bought years ago). Good luck
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
I used a brass drift and a 20lb hammer, using the same method as the post above and it drove out.
My question, and not hijack the thread but now that my drivers door is replaced it's a bit hard to close, should it be? I have the Pelican replace kit, not the added strenght plate however.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
since they're new, they are going to be a little more difficult to close...
as for pin removal... you could grab the pin w/ vice grips and wiggle the door to relieve the tension from the pin while you're pulling/twisting on it |
I have already removed the 2 screws hold the door check mechanism to the door, so there isn't any tension on it.
I think the pin is too close to the body to get a drill in there, but I will certainly give it try.
Thread Tools | |
Rate This Thread | |
