Question Delay Action Relay question
This is the relay in the engine compartment that I believe delays shutting off the CDI unit for a fraction of second(s) when ignition key is switched off.
Looking at the diagram, it seems that the S pin=switch control. Apply 12V will turn the relay on. The L pin is the "output" (i.e. it connects to pin 30 when relay is on and pin 31 if off).
Can someone please confirm that my understanding is correct (or not)?
thanks.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 03-24-2006, 12:17 PM
304065's Avatar
'79 Turbo Not Starting Ignition Question
86 930 dies at idle when warm
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-24-2006, 01:37 PM
John,
Yes - I'm talking about the same relay. Just want to confirm that the operations of the 2 pins (S & L) on the relay.
Old 03-25-2006, 07:21 AM
