question: I have a crack hose. Please read
After several searches on "high idle", I read about vacuum hose etc. I went and check and found that I have this crack hose here (pic below). I am not sure what this crack can do to the performance but I want to replace it. It is not a normal hose. It's offset and short. Do I have to buy the whole assembly (hose and metal pipe) or I can use a normal gas/oil hose at autopart store?
![]() Thanks
Fat butt 911, 1987 |
Earlier this week I replaced a few hoses on my 3.2 Carrera. The one in your picture was one of those. However i chose not to purchase that particular part because of the price ($123 part # 930 110 328 05).
So here is what I did: 1.Removed the pipe from the car 2. Cut the factory crimp off the pipe which left me with just the metal pipe. 3. Next I cut a 1 inch piece of 3/8" hose and slid it over the pipe making it flush with the end, then I cut a 2 to 3 inch piece of 5/8 hose and slid it over the 3/8" hose and clamped it. Re-installed the whole piece and clamped the new hose onto the connector. I'm pretty picky about work done on my car and do not usually rig any parts or repairs, but this time due to the excessive cost I made an exception. And to the untrained eye the repair looks great
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
Make Bruins Great Again
KC: What hose is that? Do you have any pics of your new hose setup?
rnln: What's up with the bungee cord around the air box?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I do not have pics, but will take some tomorrow afternoon and post them. What I did was very simple, I'm not sure that my descriptioin was understandable. Basiclly you have a rubber hose connecting the smaller dia pipe to a larger dia pipe. I used the 3/8" hose as sort of a bushing inside the 5/8" hose to fit on the smaller dia pipe.
Woa...for a minute thier I thought you said "crack ho".
I got a used fuel line from Carquip in Boulder CO. a while back. I'd call around and see if you can find what you are looking for on the cheap. A lot of folks put carbs on these cars so there is a market for used OEM intake stuff if you shop around.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Dont you find crack hose down on the corner?
1978 911SC #737 "D" Class Club Racer |
KCinBR,
WTH, that piece cost $123? Oh minee.. So your 2/3 short piece act as an adapter/bushing huh? Thanks for the hint KCinBR I found that I have a similar hose from my old MB. same size I think. It's the one from the valve cover to the carb. THe thing is that this hose is shape as an angle. Well, your method just works fine. What is this hose? Is it gas or air or oil? Por_sha911, still can't find a correct "hook/pin" for it bro ![]() My friend collected a bunch and gave them to me but none works swa911m, not sure what you mean. Sorry. Thanks all.
put down the crack hose.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Irrationally exuberant
See my post with pictures in this thread: Hunting down Motronic vacume leaks: What does the thermo-switch do?
It shows the hoses and the fixes. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
ChrisBennet,
On my car, this rubber hose/adapter (pic#1 below) look a little diff than yours. One end is bigger in diameter than the other end. It looks almost like pic#2 below. Where did you get that short rubber hose which has one end is bigger than the other end? If it's hard to find, I will go with KCinBR's path. Thanks. Pic# 1 ![]() Pic# 2
Fat butt 911, 1987 Last edited by rnln; 03-27-2006 at 02:07 AM.. |
-Chris
The hose I was refering to looks like this
Friend of Warren
KC mine looks like the one in the picture and was also cracked and I am cheap. I took it off, filled the cracks in with rubber cement and then wrapped it tightly with vinyl tape for extra measure. Two years later still working just fine.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Anybody know the part number on the hose/adapter in pic 2?
I noticed last night mine is split from clamp to clamp.
'86 911 Carrera ROW |
Here's ths pic of the fix I made using 2 sizes of hose:
Also the part # of the short hose in pic #2 above is 930 207 243 01
ChrisBennet,
On my car, the hose on pic#1 look like the hose on pic#2, diff diameter at each end. KCinBR, yes, that hose on my car looks like what you were talking about. I know what you are talking about. Thanks. I will do that. You cut them very straight and clean.
Audi makes a part that fits perfectly in the this application; I believe it's a coolant hose, but I don't have the part # handy. It's very cheap,
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
I've used the two hoses trick, but recently had this part replaced at a hydraulic shop-they cut off the old fitting and were able to crimp on a hose with the right id to fit on the open end. The crimp secured the hose well enough. Its on an application that sees both vaccum and now boost, and its been fine.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
