jeff1hughes's Avatar
where is my brain?
All right, where in the heck is my cruise control brain? I can't seem to find it anywhere. Also, does anyone have a pic of the wire harness that plugs into it, I'd like to find that too. I think my cars had a brainectomy, though I'm not sure. It is an 86 Targa. Thanks for any input
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 04-05-2006, 12:56 PM
try looking under the right side of your dash!!
keith epperly
87 slant nose turbo look carrera cabriolet
Old 04-05-2006, 01:30 PM
nothing there, nothing under radio, nothing next to booster in trunk
Old 04-05-2006, 05:30 PM
please help! I have a new (used) brain to try for my cruise, if I can find the wiring for the old one. Does anyone have a pic of where the OE cruise computer location for an 86?
Old 04-11-2006, 10:30 AM
madmmac's Avatar
Should be under your dash, right by the radio.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 04-11-2006, 10:44 AM
MAGA
Tim Hancock's Avatar
Well in my '79 SC it is attached to my right ankle. (sorry, couldn't resist!)
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Friend of Warren
If it isn't right under your radio then it is missing or has been relocated.
Kurt V
Old 04-11-2006, 11:15 AM
what color is the harness conector? or even the wires that make up the harness. I have found a number of cut wires in the radio area, I assumed they were all from the OE radio/amp/speaker fader. Does anyone have a pic of the connector and or a diagram of the wires that go into the connector?
Old 04-12-2006, 09:34 AM
On my '85 it was located behind the access panel on the driver's side near the windsheild wiper motor. Take the access panel off and you will most likely spot it right away. Someone decribed it to me as being about the size and shape of an 8 track tape. About right.
85 CARRERA
Old 04-13-2006, 12:06 PM
Recreational User
porschenut's Avatar
According to the Bentley manual, for an 86 it would be in the trunk where morganr770 described it. For 87 and later, it was moved to the interior directly under the radio.
However, my car has a build date of 6/20/86 and is among the last of the 86's built, and it has it inside under the radio like the 87 and later cars.
Old 04-13-2006, 02:31 PM
thanks Dave. I don't see any rogue wires under the dash anywhere, but just in case, where do the cruise wires originate from in your car? Through the front firewall, or up from the floor?
Old 04-16-2006, 05:54 AM
Jeff,
The connector is probably black and should fit over the end of the "brain." Take a look at the used brain that you have and get an idea of the connector size from the pins on the end. The wires are as follows:
1 not used
2 brown
3 white
4 not used
5 (2) black
6 black/yellow
7 grey/brown
8 brown
9 yellow
10 blue
11 black/ brown
12 brown
The numbers refer to the pin assignments and all of the wires are .5mm. Try tracing the wires from your cruise control switch to the brain connector.
As another data point; my '86 targa was built in 4/86 (#1521) and has the control unit under the radio.
Hope you find it,
JR
We need not be gracious when our enemy dies. Civility is only afforded those who don't go to their grave trying to destroy us and ours. E. M. Burlingame
Old 04-16-2006, 08:12 AM
Nine9six's Avatar
And how's that workin for ya, Tim?
Dr. Phil
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-16-2006, 09:21 AM
Irrationally exuberant
ChrisBennet's Avatar
Mine was under the radio/ash tray.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-16-2006, 09:30 AM
bigchillcar's Avatar
my '74 is simply..brainless. ahhh..'if i only had a brain..'
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 04-16-2006, 09:49 AM
