where is my brain?
All right, where in the heck is my cruise control brain? I can't seem to find it anywhere. Also, does anyone have a pic of the wire harness that plugs into it, I'd like to find that too. I think my cars had a brainectomy, though I'm not sure. It is an 86 Targa. Thanks for any input
86 Carrera Targa - Garnet Red Metallic 88 928 S4 - Gran Prix White |
try looking under the right side of your dash!!
keith epperly 87 slant nose turbo look carrera cabriolet |
nothing there, nothing under radio, nothing next to booster in trunk
please help! I have a new (used) brain to try for my cruise, if I can find the wiring for the old one. Does anyone have a pic of where the OE cruise computer location for an 86?
Should be under your dash, right by the radio.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
MAGA
Well in my '79 SC it is attached to my right ankle. (sorry, couldn't resist!)
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Friend of Warren
If it isn't right under your radio then it is missing or has been relocated.
Kurt V No more Porsches, but a revolving number of motorcycles. |
what color is the harness conector? or even the wires that make up the harness. I have found a number of cut wires in the radio area, I assumed they were all from the OE radio/amp/speaker fader. Does anyone have a pic of the connector and or a diagram of the wires that go into the connector?
On my '85 it was located behind the access panel on the driver's side near the windsheild wiper motor. Take the access panel off and you will most likely spot it right away. Someone decribed it to me as being about the size and shape of an 8 track tape. About right.
85 CARRERA |
Recreational User
According to the Bentley manual, for an 86 it would be in the trunk where morganr770 described it. For 87 and later, it was moved to the interior directly under the radio.
However, my car has a build date of 6/20/86 and is among the last of the 86's built, and it has it inside under the radio like the 87 and later cars. |
thanks Dave. I don't see any rogue wires under the dash anywhere, but just in case, where do the cruise wires originate from in your car? Through the front firewall, or up from the floor?
Jeff,
The connector is probably black and should fit over the end of the "brain." Take a look at the used brain that you have and get an idea of the connector size from the pins on the end. The wires are as follows: 1 not used 2 brown 3 white 4 not used 5 (2) black 6 black/yellow 7 grey/brown 8 brown 9 yellow 10 blue 11 black/ brown 12 brown The numbers refer to the pin assignments and all of the wires are .5mm. Try tracing the wires from your cruise control switch to the brain connector. As another data point; my '86 targa was built in 4/86 (#1521) and has the control unit under the radio. Hope you find it, JR
We need not be gracious when our enemy dies. Civility is only afforded those who don't go to their grave trying to destroy us and ours. E. M. Burlingame |
Dr. Phil
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Irrationally exuberant
Mine was under the radio/ash tray.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
my '74 is simply..brainless. ahhh..'if i only had a brain..'
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
