yeuporsch's Avatar
Is it better to use wheel adapter than using spacer with longer studs?
I want to know which is better to use to widen wheel track? Which is acceptable for DE events?
Thanks,
John
Old 04-05-2006, 03:14 PM
ttweed's Avatar
It is better to use longer studs and a spacer. Some clubs will not accept adapters for DE events.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-05-2006, 04:50 PM
John,
Other than some clubs not allowing adaptors, it is more tedious to check the torque values with adaptors since you have to remove wheels to check the inner nuts. I'd go with longer studs and spacers if doing track events.
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 04-05-2006, 05:06 PM
Grady Clay's Avatar
I will chime on 3rd. Not only are there the above issues but the physical strength of the adaptor now becomes an issue.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-05-2006, 05:12 PM
All true enough.....
but look how a front hub is "attached"....same principle as an "adaptor" with an offset series of 5 bolts holding it on....
Still...I'm in agreement here and would prefer longer bolts with a "spacer".
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-06-2006, 07:40 AM
