993 Brake Upgrade - Whos using 7x16 fuchs
I read that to use the 7x16 911 offset fuchs you would need a 1/4 inch spacer. I just finished putting on my 993 on the SC and while I don't have a spacer it looks like it would need to a lot more than 1/4 inch. Anyone out there actually done this with a true 911 offset fuch.
Also interrested if anyones using 951 offset 7x16 without spacers. My set up uses a 309mm rotor. Thanks Jeff
Jeff C 76 912E 2.6L |
Not exactly the same but I'm using 951 7's on the front with 930 brakes. I have 911 7s on the rear with 5mm spacer. The fins have been filed on the calipers.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Driving member
You need to get the skinny from Bill Verberg. He is the brake guru here.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Bump for the west Coast
951 fuch's
I have used 951 7x16 wheels on my 911 with the 993 brakes and the large Coleman rotors without spacers. Bolt-on fit. I have a set for sale if your interested.
I also have a set of 951 8x16 fuch's on ebay right now. |
Jeff,
I am using 951 16x7 with 309 Coleman 2 pc rotors from ProBraking. It's a tight fit but a fit nevertheless.
76 Carrera 3.0 (Group Sc) |
Thread Tools | |
Rate This Thread | |
