RETIRED
My first 3.2, starting issue
So....cranking the motor, starts and immediately dies.....what do I adjust?
Stepping on the throttle while cranking does nothing....bump starts and runs immediately....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Diss Member
You don't have it listed so not sure if it is a stock Carrera, something with a stock Motronic driving it, or some sort of Frankenstein abortion thing with carbs, MFI, or CIS on it...
One thing is that a Motronic car is supposed to be started with no throttle input. Just turn the key.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
RETIRED
Yep....it's stock...but it's in a 914/6. LOOKs like I have it narrowed down to an issue with the ignition switch.
Autobahn Garage
DME relay??You may want to check into that I have replaced those to cure the same problem
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
