911/01 transmission internals question
Well, after inspecting all the internal parts of my 911/01 transmission the only wearing I could find was on the 1st gear slider and reverse gear. I could not find any wear on the syncros or dog teeth of any gear. The weird part is I got grinding going into 2nd gear, but looking at everything 2nd gear is fine. Is this possible or am I just blind when it comes to inspecting these parts? Can the 1st gear slider and reverse gear be the only parts that wear without other parts wearing? I wish I could post pics but I can't find my damn camera
Thanks.
Amir
1970 911T
1967 912
Old 04-28-2006, 10:51 PM
Found my camera!
Here is reverse gear
Here is 1st gear slider
Amir
1970 911T
1967 912
Old 04-29-2006, 08:23 AM
any polishing on the curved surface of the syncro ring can cause grinding. the grinding is the teeth on the shift sleeve contacting the teeth on the dog tooth ring at different speeds because the syncro didn't slow down or speed up the free-wheeling gear to match the speed of the driven gear as the shift sleeve passed over it. the syncro's friction surface condition is very important. brake bands and the condition of the inner leading tooth face of the shift sleeve are other issues that affect shifting quality.
206 637 4071
Old 04-29-2006, 08:54 AM
Cordts's Avatar
Amir.. what did you do to take care of the problem going into 2nd?
1967S Porsche Targa #500317S EURO
1972 BMW 2002Tii
1967 Triumph TR4a Irs
1967 Austin Healey "Bugeye" Sprite
1966 Austin Healey 3000 MKIII
Old 01-18-2007, 01:17 PM
Grady Clay's Avatar
Amir,
Have you disassembled 2nd gear syncro? There can be all sorts of subtle (or at least not obvious) issues that can conspire to prevent good synchronizations.
Lay the pieces out in their original orientation and post some good clear images. The Forum can lead you through the process.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-18-2007, 02:38 PM
I sure hope someone can post some pictures. I'm very interested in learning all the little things to look for ?
Thanks, John
John Ashford
Towson, MD
John
Old 01-18-2007, 03:51 PM
