While The Engine Is Out...
Maybe I'm not searching w/the right terms...
Engine's out during a top end rebuild. So what are some things I can (or should) do now that I would likely curse over if I waited until after the engine's back in. Keep in mind I am very much a non-wrench (but I'm hoping to be reformed). Thanks.
SC |
one of gods prototypes
i'm in the middle of an engine compartment cleanup, today was spent cleaning 20 years of grime out and removing most of the engine pad glue...i'm suprised it's still so white, didn't think to take a before pic
Brought to you by Carl's Jr. |
- check clutch and flywheel
- check CV joints - replace shifter bushings and shift coupler - inspect all hoses and replace as necessary - inspect condition of wiring harness - clean all goop out of engine bay and (particularly) transmission tunnel area, check for rust - replace engine compartment sound pad if it is falling apart - repair any damaged undercoating |
search up past threads for many ideas on this
I'd prob. do a new clutch cable, and for sure clean the engine compartment & put in a new sound pad. It's a dirty job - here's what I looked like after I finished...
Wouldn't it be wise to 'freshen up' the bottom end at the same time if it has not been done recently?
76 Carrera 3.0 (Group Sc) |
Thermostat O-ring
Oil light sender Breather gasket Main seal Fuel lines ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Replace pressure switch.
Alii&Maui
replace rear shocks
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
Licensed User
coilovers, gearbox rebuild, full restoration, etc.
