LinkBack | Thread Tools | Rate Thread |
Help - My engine was sabotaged! - need advice - rebuild or replace
What a dark and mysterious story.
I bought an 81' SC a three years ago with 130,000 miles. I recently discovred that at some point in the past someone put a foreign substance in the oil tank. I recently discovered this when my new mechanic Frank (whom I do trust by the way) did an oil change. I was hanging out chatting with him while he did the oil change and he pointed out some weird crud on the drain plug. We then scrapped around in the oil tank and discovered a course, grainy substance, which my mechanic thinks is "Absorbal". I'm still dumbfounded as to how and why it got in there, but our best guess is that a former mechanic put it in there to create mechanical problems. I also wonder if the prior owner didn't pay a bill and this was some kind of payback. Anyways....I've got no recourse to anyone....so here I am. Most recently, the car was making a terrible knocking in the valve train and the following is what Frank discovered. The oil feeder tubes to the cam & lobes are clogged with crud. The oil starvation has ruined one cam and caused who knows what damage to the rest of the top end and the rest of the engine. So here I am........the key question is what to do next. Can I ask for some feedback on the following (all amounts are in CDN $ = 90% of a US dollar): A - Spend $3,000 to replace cams, the cam followers, basically deal with everything "above the heads". While this may improve things in the short run, I still have the issue of likely long term damage to the bottom end and the heads, so I may be just postponing more expensive problems B - Buy a used engine. Frank has offerred to sell me a 3.0 ltr (79') engine from a car that he is swapping a 3.6 into. This would be subject to a proper leakdown test, etc. Cost $4,500 installed. Keep in mind that the supply of engines up here in Canada is not the same as the states. C - Completely rebuild my engine. Cost $8,000 I'm at a tough spot here, because part of me tells me to "dump the car". I bought the car for $20,000 and have put in $10,000 in upgrades and repairs to date including: 7 & 9" Fuchs with SO3s SSIs Turbo tie rods. None of those upgrades are going to improve the resale value up here in Canada, so even if I put $3,000 into her under option A and then try to sell the car, not only would I only get $20,000 if I'm really lucky, but I'd have the bad karma to deal with. Its never really run well anyways...which has hurt my "happy owner factor", so I guess my instinct is to suck it up, buy a good used engine and get on with life and take this as an important life lesson (MEAN PEOPLE SUCK) When will the money pit end?
Garage is empty Gone:96 TVR Chimaera, 05' Mazdaspeed MX5/89' Caterham Super Seven/84' Carrera/81' 911 SC targa/74' MGB |
Why wasn't this discovered at the first oil change after purchase? Am I missing something here?
David 1972 911T/S MFI Survivor |
I asked myself the same question.
Would some mechanics ignore a bit of crud? What do I do, now that the deed is done, I'm still faced with the problem. Which of the 4 mechanics that I have dealt with do I go after? Who do I trust? I'm stumped... On the plus side, my current mechanic Frank is a LOT less expensive than other mechanics, I've known him personally for a few years and everyone who knows him says good things about him. There was a guy there tonight who takes his 79 turbo to Frank that he has owned since new. He has put a fortune into that car (382 RWH) and he trusts Frank to work on his car...would he have that kind of loyalty if he screwed people over?
I feel your pain!!! I would go with the used 3.0 for now, Break down and sell the parts from your old machine, the good ones.... and upgrade to a 3.2 or something down the road. Move on and drive away from the bad memories. Best, Gordon
1984 RoW Cabriolet (needed me-followed me home) |
what should I ask for as a "core value" for my motor?
I'd rather not try to sell off parts on my own? My mechanic says he is paying $4,000 for the 3.0 as part of his trade on selling the 3.6. He is telling me he will charge me $4500 to swap the engine, put my SSIs on it, etc. Also, what kind of warranty should I ask for? Should I shoot for $3500 to factor in the value of the current parts, or does my suspect engine really have no value? Either way...I'm going to get a second opinion.
Your motor condition is unknown. Assuming crank,rods,case,and misc. are ok, a BIG assumption by the way, it may be worth, 1200 to 2600, big guess!!! Warranty on used would be hard, but 90 days or 3000 miles should indicate reasonable health . Your engine could have major damage, so value is impossible to say. swapout costs sound reasonable, The 3.0 condition should be backed up by records, mileage, comp. test etc. G
Cars, boats, bikes and the like are all burn barrels we throw money into, hence the love hate relationship.
With the original motor a full rebuild is required, doing it half way with what you decribed is a bad idea. A swap is a quick way to get back on the road. WARNING!!! Fully clean out the tank, external oil thermostat, oil lines, and front cooler. You don't want any of the mystery crud in the new motor. Good luck It wil be worth in the end
'80 SC 911 '67 Chevy SS Nova - Supercharged '99 GSXR track only, '99 Superhawk '05 Toy PU - daily driver |
The people who do this are absolute lowlives!
"It looks like a Pleco.." |
Re: Help - My engine was sabotaged! - need advice - rebuild or replace
I'm not here.
Things that make you go hmm...
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) |
if you get really exercised about this, you could hire a forensic chemist... a good criminal lawyer will know how to get one -- or if you have friends inside of the the Canadian "EPA"
- won't be cheap but he can compare that with items your lawyer gets from the shops of the 3-4 mechanics he does discovery on...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
As said before, spring for the rebuilt 3.0 with the upgrades from yours. Sell off the good parts from your trashed engine (have the mechanic tell you want is good & what is not), and drive off into the sunset. Your mechanic is giving you a good deal for that engine installed. If you get a little warrantee, that's even better. You might document it with your mechanic and save some of the crud in case you decide to do something down the road.
Marv Evans '69 911E |
I'm with Randy on this one as I'd like to know what I'm dealing with.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Below the Rim
Do the oil analysts check for stuff besides metal? I've seen their ads - send them a vial of your drain oil and they'll send you a report on the health (or not) of your powerplant. Just a thought.
1979 911SC Coupe |
Designer King
Go for plan B. I've used Frank recently for some major work, and I know Bill too (turbo owner). Frank seems honest and competent, and his hourly rate is reasonable. Can he do a compression and leakdown test on the replacement engine for you first?
When it's fixed, send us some pictures and enjoy driving it!
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Supertec offers a 2 year unlimited mile warranty on their rebuilds! You should definitely consider going with Henry - his rep is outstanding. And he get engines sent to him from all over the world! 760.728.3062
For a little more you can get a 3.2 engine instead - psychologically it might feel better to pay all that money and be at least a little ahead of where you were when you started. =)
typically, oil analysts check fo silicon ('dirt') and a few organics, such as acids - call to see what each does
Be sure to save all the gunk with a witness watching - have them record on paper the date/time and what you are doing - this is essentially what the National Water Quality Lab & EPA etc. do when they get in samples from what looks to be an illegal operation - they want it to stand up in Court the std. oil analysis will be very cost-effective - send them some of it, but by no means all You might also write a letter with all the names of the shops on the letterhead and send it to them -- see which one starts cleaning up big time & you may have found the perp. Altho you have given a very dark tale, it is still possible that a simple mistake was made... I agree re the 3.2 - the heads flow a lot better too. Or maybe a 3.6 would be fun.
Bland
If I was you, I'd have taken the oil filter apart to see how much crud was in there. A bit of dirt in the oil should get cleaned out by the filter the first circuit through the oil system. If there is heavy crud in there, it likely would stay put in the bottom of the tank until is was drained out. If it's still in the tank, it hasn't caused any damage - right?
The fact that any crud remains would suggest that the crud made it's way in there between this oil change and the previous one. Another possible source of crud is if someone drained the oil to set the valves and then poured it back into the engine afterwards.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
The way I read this tale of woe, no way to find out who, or when the foreign substance was added. ANYONE with access to your car could have done it. Disgruntled girlfriend, a guy you don't get along with, the list could be a long one. So, probably best to try to forget about the who done it stuff, move on into the how best to get back on the road stuff. Does your car insurance cover vandalism? There may be some financial help due from the insurance company...My insurance covered a long ago engine fire in my 1970 911T.. Your insurance would probably insist on a stock engine rebuild, IF you're covered.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
