JoeMag's Avatar
Removing roll pin in front shocks...
I have front coil overs on my car. Are there special tools required to remove the roll pin that holds the insert in the spindle assembly.
Smacked it a few good times with punch and didn't move. Before I beat the heck out of it figured I'd check.
thx,
Joe
Old 05-23-2006, 05:38 PM
oneblueyedog's Avatar
I think the process is to leave the nut on the end loose and whack it with a brass hammer so the flat end comes out the side. It's tapered and shaped.
78SC coupe, Silver Metallic
Old 05-23-2006, 07:09 PM
DW SD's Avatar
Need some clarification. Are you talking about the rollpin which anchors the bilstein shock instert inside of the strut?
(You can drive this out with a punch of similar diameter.)
OR
the threaded wedge pin which retains the strut assembly to the ball joint?
Doug
1971 RSR - interpretation
Old 05-23-2006, 07:12 PM
efhughes3's Avatar
If you refer to the rollpin at the bottom, whack it (that didn't sound right) out with a hammer and punch. I just did mine Sunday-not too hard, but they take a little bit of force. Of course, if you go too craxy, you could bugger it up, but they're pretty tough.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-23-2006, 07:18 PM
My apologies. I missed the coil over part.
Old 05-23-2006, 07:24 PM
