randywebb's Avatar
Saving your Swepco 201
A lot of us save the left over quart or so of Swepco 201 when changing the trans. oil.
Just for fun, I called Swepco and asked them what the shelf life was. They said 1 year (tho noted that there were many out there that were older with no apparent problems, but they "would really want to sample [and test]that.").
So if you are one of the people who saves a qt. each time (say, each year) and on year 4 you have all you need to do antoher change, ...
well, be advised.
Interestingly, when I've asked for info on shelf life of greases, the only co. that responded said, 2 to 5 years.
Old 05-26-2006, 01:37 PM
Automotive Monomaniac
Emission's Avatar
If the shelf life (sealed container at room temp) is only one year... how come you can keep it in the transmission (with frequent high temperature cycles and pressures) for many more years without issues?
I am a skeptic on the "shelf-life" issue... unless the chemicals "settle out" or something.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-26-2006, 01:45 PM
defcon65's Avatar
I suspect shelf-life quotes are derived from limitation of liability policies: if they were to tell you it was good indefinitely they might assume some liability for your using their defective product.
Plus Swepco wants you to think their stuff is really special so you'll discard the perfectly good 'dated' product and shell out another $40 for a gallon.
Honestly, the simple solution is to own four 911s and buy three gallons at a time. No waste!
Old 05-26-2006, 02:04 PM
or change the tranny oil every three months...
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 05-26-2006, 02:18 PM
randywebb's Avatar
re "settle out" or something -- the something would be chemical reactions -- that's what chemicals do...
re "how come you can keep it in the transmission (with frequent high temperature cycles and pressures) for many more years without issues?"
-- How do you know there are no issues? You may bvery well have accelerated the wear on your gears and synchros by 300%. You wouldn't know that w/o a statistically valid study after several years or longer.
I have no idea re their motives. I generally look at a business, esp. one that survives based on product quality, as honest -- until I know better. No reason to suspect otherwise here.
I'm not sure this will push me towards changing the trans. oil every year, but it is interesting information.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-26-2006, 02:26 PM
Emission's Avatar
I'm not arguing with you Randy - just thinkin' things through.
I think the best explanation is the "product liability" issue. I've never read of anyone having a tranny fail because their Swepco was old...
Old 05-26-2006, 02:31 PM
If one followed the advise to dump extra diff. oil after 12 months, I'd advise against buying that product. The lube couldn't be that good in the first place if it has a limited shelf life.
Why would unused Swepco in an opened container be any different than a gallon of new Swepco? Is it hygroscopic like brake fluid? Does Swepco dump NOS at 12 month intervals? Do they advise their dealers to do likewise? Are their containers dated?
I'd chalk it up to a silly comment from the Swepco person or think seriously of changing to a more stable gear lube.
Why don't we all write to their consumer affairs dept.?
Sherwood
Old 05-26-2006, 03:37 PM
Crotchety Old Bastard
RarlyL8's Avatar
They wouldn't sell as much product if it lasted forever.
This is all sales BS. The fact that most trannies NEVER get the gear loob changed aught to raise more than a few eyebrows.
Old 05-26-2006, 04:29 PM
PPilot's Avatar
Hmmm...Water is very reactive, and very old...is it all obsolete too..just kiddin....
1984 RoW Cabriolet (needed me-followed me home)
Old 05-26-2006, 05:14 PM
randywebb's Avatar
I agree re the best explanation being "product liability" - or just a general tendency to err on the side of conservatism.
Rarly - you don't know whether it is sales BS or not... but the fact that many transmissions run with very long or no fluid intervals definitely should raise questions.
Sherwood - I suspect the shelf life already has typical factory, distributor & retail time lags figured into it. Agreed re pull dates on the container.
I don't think I'll be saving the stuff for 4 years to put it in my trans. tho.
Old 05-26-2006, 05:15 PM
Todd Simpson's Avatar
OK, so what about shelf life for Mobil 1 synthetic?
I just picked up 62 quarts of it.
Yes, 62 quarts. At $3 a quart you stock up.
Old 05-26-2006, 06:31 PM
RarlyL8's Avatar
Well I do know that I'm not stupid, something most sales people expect from the general public.
Oh, and the fact that I'm a chemist probably doesn't hurt either.
Old 05-26-2006, 08:32 PM
Hmmm ... I've got some Sears bearing grease that I got from my Grandpa's garage when he passed away 25 years ago. It's a rusty old can, but I still use the grease here and there (although not for my gearbox!). Seems to work pretty good.
Old 05-26-2006, 09:01 PM
Zeke's Avatar
IIRC, while reading about South West Petroleum, they primarily manufacture lubricants for industrial use and heavy equipment. Under the conditions that most of their product endures, I would think their philosophy is correct.
Furthermore, I believe they really don't promote their products for our type of use like, say, Redline. It would be interesting to hear what the Redline folks say. Certainly RL has a stellar reputation amongst racers.
Mr. Webb, you stirrin' up the pot....aagin?
Old 05-26-2006, 09:20 PM
Immature Member
dentist90's Avatar
If one does want to keep the left over quart (or Litre, eh) I think it would be a good idea to transfer it into a 1 quart, well-sealed bottle. In doing so you remove the three quarts of room air that would otherwise share the space with your oil. There would be less chance of oxidation or water vapour contamination. Having said that, I just can't imagine that a hydrocarbon that has been sitting in the ground for a billion years would have a fixed shelf life. But we all know that gasoline has a very predictable lifespan, but it is more volatile. Now I've confused myself. Luckily the stuff I put in comes in 1L containers so I don't have to think so hard about these things.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-26-2006, 09:26 PM
randywebb's Avatar
Well, I thought it was interesting & people would be interested -- my point is we really don't know...
If I wanted to stir things, I guess I'd go to Fchat.
But what would a guy with only 13 posts know about past stirrings?
Old 05-26-2006, 09:37 PM
Emission's Avatar
I think it's very interesting!
You never know, the guy with 13 posts could have been lurking for five years, twenty hours a week... and have notes on all of us!
Old 05-26-2006, 09:44 PM
randywebb's Avatar
Yeh, I bet he's been around for a while...
Old 05-26-2006, 09:49 PM
Zeke's Avatar
You think?
Who is that guy ??
Old 05-29-2006, 10:09 PM
defcon65's Avatar
I've got a bottle of Chateau Mouton-Rothschild, been in the cellar since '68 - this stuff can't be good anymore....
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 05-30-2006, 07:01 AM
