engine is out, now questions
The engine is out, and I managed to do it solo...with an ATV jack and a floor jack under the transaxle.
When I pulled the flywheel off, I found this wax like substance? What is it...I'm replacing the clutch anyway...
Need a new rear seal, what type of sealant should I use? I already purchcased the Reinz seal.
How does this throw out arm look... should there be a plastic washer at the top and bottm, there is only one in the photo below.
86' 911 Carerra
Old 05-28-2006, 10:18 AM
Bill is Dead.
cashflyer's Avatar
The substance looks like old, geletanized grease.
There should be a little seal at the bottom of the arm pivot. In fact, PP catalog shows that 3 are required - PN 915-301-139-00-M30. I think the third went on the outside of the shaft where it comes through the housing. They are flimsy items that wear out and disappear in short order, so I'm not sure how critical they are.
I don't recall any sealant being used along with the main seal when replaced.
Old 05-28-2006, 10:36 AM
Should the rear seal go in "dry", or should I use a coating of oil or sealant etc...?
86' 911 Carerra
Old 05-30-2006, 11:00 AM
Bill is Dead.
cashflyer's Avatar
I just coated mine with motor oil for installation. I don't know if there are any differing opinions on this.
Old 05-30-2006, 11:14 AM
David's Avatar
I use white lithium grease on seals, but motor oil probably works fine.
Old 05-30-2006, 11:22 AM
mppickett's Avatar
Oil works. I like the Dow Corning 111 silicon-based lube for o-rings and seals.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 05-30-2006, 11:26 AM
PJMARKOW's Avatar
Careful with the number of seals and their placement on the throwout arm. I thought I was doing the right thing when I replaced the "missing" seal on the throwout arm on my 1977 930. Then I couldn't align the gearbox with the engine/clutch. We tried for about an hour, but no dice. Removed that "missing" seal and that solved the problem.
Cheers
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 05-30-2006, 02:39 PM
PJ, do you remeber how many seals you ended up using? Did you use one above and below the throw-out arm?
86' 911 Carerra
Old 05-31-2006, 08:52 AM
Bill is Dead.
cashflyer's Avatar
911 (1974-77, 1 req.)
911 (1978-86, 3 req.)
911 Turbo (1976-77, 2 req.)
Old 05-31-2006, 08:58 AM
Virginia Rocks!
VaSteve's Avatar
Mine was missing the third seal. I bought it, but nevr installed it. Seems to run/drive/shift fine without it...a year later.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-31-2006, 11:18 AM
MBEngineering's Avatar
HI the seals are ok in the bellhousing like the photo, when you fit the flywheel seal , fit the new one back the same distance in as the old one, or expect a OIL leak!!!
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 05-31-2006, 12:43 PM
PJMARKOW's Avatar
My car had only one seal, the one above just like your car. I thought that maybe the bottom one was missing, but obviously they assumed you'd only get gunk in at the top, as the throwout arm runs flush at the bottom.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 06-01-2006, 12:53 AM
