Odometer not working
Before I tear things apart I wanted to know if anyone has suggestions on what the problem is.
My speedometer works fine, however the odometer is not racking up my miles. I have driven about 60 miles and it only went about 1/10th of a mile? any help is appreciated. |
Which car? Get the Wayne Dempsey: 101 Projects for your Porsche 911. It gives you the fix. It is probably the big toothed gear that is turned by the electrical wormgear motor. That was what was wrong with mine. It is a very common problem. You need to take it apart to verify which part then order it through Pelican parts.
'94 VW Jetta '85 VW Scirocco '81 911 SC coupe Euro '67 VW Bug |
I always forget to list what I have.
'76 911 915 trans 3.0ltr Thanks Huh, I have the book and will check it out. |
If its the gear, you will know it the minute you pull the speedo apart...the gear usually will just crumble to pieces. I bought a replacement gear ahead of time and i replaced the gear and had the speedo back in and working within an hour. Just need to be careful when you remove the speedo documenting the wiring configuration, etc. If you take your time you should be fine.
86 911 Targa |
Turbo-Mag throw you car in your sig. It really helps other people help you.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Anyone know the part number for the odometer gear. I have a 82 SC and need to fix mine but am having a heck of a time finding it from our host
Thanks Steve
1982 SC |
Driving member
I don't think the gear is for sale here. Do a search for something like odometer. com . They sell the gears you need.
Or send it to a speedo shop. Chances are with the age of these gauges, they need refurbishing anyway.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Driving member
Click on it and follow the links.
Try North Hollywood Odometer, they have all the parts and service the VDO gauges. They have a website.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
1984 Targa |
