uh, 964 cams are stock on the 964... they are an upgrade on earlier motors
- was that your question?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
yes u answered my ques. thks damian
OK - if you search on those 2 terms you'll find a thread where someone explains the advantages
IIRC, it is a cam that allows better breathing but still works on on CIS motors the ramps may have a newer, more complex desing also
Now in 993 land ...
All other things being equal - and I know that's very theoretic - the displacement increase will increase power in linear proportion. 3.0 to 3.2 is a 6.25% gain.
Gerge |
Now in 993 land ...
Cheers, George |
I have spoken with John and I have selected him to regrind my cams.
I have decided to purchase the 98mm P+Cs from Henry. Just to temporarily place a halt on expenses, could I use the 20/21 or S cams, the stock CIS, but in the future be able to switch to carbs without tearing up the engine again? As a reminder, I do have the early 3.0 with bigger ports. Thanks. |
Now in 993 land ...
You want to put CIS on there for now and go to carbs later? The S cams will not work. The 20/21 cams are run by others with CIS, if I remember right. rdane? That should be a compromise. So, I'd go as hot as you can with CIS (Joh will know what cam will work best) and then not worry about it later. And if you have the carbs and you just have to tickle the last bit out of it, changing cams is not a big deal. You could wait until the first time you have to take the engine out for another reason, like a clutch or an oil leak...
Cheers, George |
Right, "real" S cams will cause the valves to hit the CIS pistons. You can stay with the so-called 's' cams that were used on the CIS engined- 911S cars from 1974-77 -- they are not really S cams. So don't get confused about this. Most call them CIS cams.
You can however, put carbs on now (and SSIs) and enjoy the feel, the induction noise and maybe a tad more power. Then later, you can change the cams and pistons to get a real power increase. Steve Wiener has posted on this and I used ot have a '75 done this way. So yes you will have to tear into the engine again. It will cost more eventually this way, but the cost per year or whatever increment will be lower. You have to think about whether this makes more sense or if [2] you should get a loan to do it all now, or [3] just wait and save your $$ for a year or two (the cheapest for sure).
Randy, The 98mm's are the QSC's. They will have JE pistons, not CIS pistons. Am I all confused? The $$ is not really an issue. My approach takes into account that I am a newbie and I really do not want to buy all the hipo stuff, put it together, and it blows on my face. In other words, I want to take the 'baby step' approach. BTW, the car actually came with non-SS exhaust (2-in 1 out muffler). Unfortunately, they are a little bit rusty and maybe would buy the SSI down the road. |
Now in 993 land ...
The reason why you can not use "early" S cams on ANY CIS equipped engine, regardless of pistons, is the single plenum setup of the intake. The CIS air metering flapper will get too much "pulsing" from the cylinders and will get confused. Again, this is regardless of the pistons and limits your cam choice to something less aggressive.
George |
I built an RSR spec 3 liter for my RSR clone. The engine makes gobs of power right up to 7500 RPM yet is is comfortable to drive on the street. Spent the day today at the Glen. What a blast to drive at the track!
Here's the details: Another RSR Clone Project - Dyno Day
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
A Quiet Boom/Chris has turned me on to some great carb info over the course of our friendship..
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
l guess carbs we go!
So, who's got webers? Could you supply me the part or model number? Thanks. ps., Maybe someday we'll go to PMO. |
Not to discount other build needs but the point being I'd wait it out for Competition Engineering. imo pick a cam to perform max torque where it's needed instead of max HP and use CE for at least your head work.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
