Easiest way to replace window switch...
my driver's side window switch is dead, already have a new one in hand. I was able to pop out the current one, but didn't disconnect anything.
Found the diagrams through search, although for an 84, I have an 88. Easiest way to do this, and will I electrocute myself
Sean 1988 911 Coupe Blk/Linen 1992 Mercedes-Benz 190 2.3 1999 Honda Accord LX 2003 Kymco People 50 (city killer) |
You won't electrocute yourself, but you could always disconnect the battery if you want to. If there is enough wire slack to move them one at a time from switch to switch that would be the best, otherwise write down each wire color and the terminal number it goes, a diagram would not hurt nor would taking a picture with a digital camera before you disconnect anything.
they all looked the same color, but i didn't look that long, do they just pop off?
2nd the battery disconnect. Get out a pen and paper and draw!!
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
not sure if i want to disconnect the battery, i'm handy, but not that handy.
Black and Blue
are the wires hot if the key isnt in the ignition and turned? or is it a connect the ground kinda thing where its hot all the time? i swapped mine out without disconnecting a thing. I guess you could get a voltmeter and test the wires to see if any are hot.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
omg, its 12 volt
swap one wire at a time, if your concerned disconnect the battery, if your not handy enough for that you better go to a shop and spend some money. Dont mind me Im grumpy today.
theamsoilguy@hotmail.com |
Friend of Warren
You don't need to disconnect the battery, but you really need to learn how to do so in case of an emergency. There are several different colored wires so draw a diagram.
Kurt V No more Porsches, but a revolving number of motorcycles. |
dumb Q...do i need to remove the door panel to install the new switch, or is it Pop out, pop in?
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
You can pop them in and out. Draw a diagram, then replace one at a time.
Then only snag you could hit is while you are pulling the switch out, the slack could not be enough and the wires could pull off the post.
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
Put feet in bucket of water, turn on ignition switch and remove wires.
Sorry I must be grumpy too. Actually I just did this 2 weeks ago - just remove one wire at a time and install on new switch. If it takes more than 2 minutes you are doing something wrong.
Bill 87 911 Targa 06 Toyota Sequoia |
i didn't know there was a hard way.
Make Bruins Great Again
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
i'm not ignorant, just not familiar with this one yet, i do a lot of stuff myself that I can get my hands around.
Sean
Battery is located in front of car on the drivers side. Knowing this you should be able to disconnect it since you do a lot of stuff yourself. If this doesnt help get a pair of bolt cutters so you can cut the wires.
----------------------------- Ernie 81 SC |
no need to disconnect the battery. no power there unless the key is on.
