AC condensor fan
I have an 86 Carrera that I have put all new hoses and components for the AC system in. I have good cold air again. The fan in the front that blows on the front condensor is not getting any power. I have tried all different settings. I see in Bentley that there is a relay for this circut. Can you tell me where it is located and how can I test its operation? I have checked the fuses. Thanks
Old 06-20-2006, 01:48 PM
ruf-porsche's Avatar
Relay on the earlier 911 such as my 82sc was located in the smuggler box.
You can spend beaucoup bucks and buy a Porsche genuine part that is made in China or go to rat shack and buy their automtive relay which is a direct fit for under 5 bucks.
Old 06-20-2006, 03:31 PM
bigchillcar's Avatar
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-20-2006, 03:38 PM
The relay in the smugglers box for the A/C....which used to have an internal diode prior to '88...was updated in '88 to include an "external" jumpered connection and an installed fuse.
Alan Caldwell who writes on such matters in Panorama.... also described this change and it made no sense to him, (nor to me ....nor to any other person who understands electrical circuitry).
I went ahead and installed this goofy updated relay anyway.... can anyone here explain the function of the external fuse ??
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-21-2006, 08:15 AM
- Wil
Yah Das is known as German Engineering!!
They over engineer everything.
Old 06-21-2006, 06:39 PM
Senior Member
The fuse is to keep the car from burning up when the fan siezes, which has happened hundreds of times in the field.
If your car does not have a fuse in the inline power wiring to the condenser fan, it needs one.
Old 06-21-2006, 06:51 PM
Joeaksa
You're confusing the front condenser fuse addition ( 7.5A ATO style added by the factory in '88)...with the external fuse that piggy-backs on the relay mounted in the smugglers box. Neither I nor even Alan Caldwell from Pano...who writes about such things....can explain the logic for this piggy-back arrangement.....
- Wil
Wil Ferch
Old 08-17-2006, 09:36 AM
+ lurking - contributing
Stunistu, must ask how hard was the barrier hose install, DIY?
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 08-17-2006, 03:24 PM
scottb's Avatar
It's not difficult, but it is a dirty time-consuming job. The hardest part for me was snaking the hoses into the engine compartment with the ends attached. Some people have bought bulk hose and then have the ends crimped after installation.
The bottom line is that it's a very DIY-able job.
1984 Targa
Old 08-17-2006, 04:20 PM
I had this same issue on my '89 and it turned out to be a bad relay....it should be up front, in the trunk fuse box.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 08-17-2006, 05:24 PM
