vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Intermittent Turn Signal Issue - Help?
Been having an intermittent issue with the turn signals - they do not work at all. Replaced the stalk a couple years ago so do not think that is the issue. When they are not working the emergency flashers do not work either. Where do you suggest I start?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 07-14-2011, 03:19 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Have you check to see if you get voltage at the sockets or if the wire connected at the fuse panel is not loose?
Get a DVM to see where the power terminates, If at fuse then probably a loose wire, if good then if at the socket then:
YOu would need to check the PCB ( board ) in the housing it self to see it it is broken:
It is the one underneath. Mine was fractured in half and worked intermittenly but finaly shorted out when the wire hit the housing.
'85 Carrera Targa
PCA/POC
Old 07-14-2011, 03:30 PM
