Intermittent Turn Signal Issue - Help?
Been having an intermittent issue with the turn signals - they do not work at all. Replaced the stalk a couple years ago so do not think that is the issue. When they are not working the emergency flashers do not work either. Where do you suggest I start?
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Member 911 Anonymous
Have you check to see if you get voltage at the sockets or if the wire connected at the fuse panel is not loose?
Get a DVM to see where the power terminates, If at fuse then probably a loose wire, if good then if at the socket then: YOu would need to check the PCB ( board ) in the housing it self to see it it is broken: It is the one underneath. Mine was fractured in half and worked intermittenly but finaly shorted out when the wire hit the housing.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
