Elombard's Avatar
Setting up a differential (preload and backlash) DIY?
Check out these instructions for doing it on a Miata.
http://www.miata.net/garage/diff_rr.html
Looks pretty simple, requires $70 or so bucks in tools.
How different is it to do this for a 911 diff?
The reason I ask Is I would like to add an LSD but the labor to have it installed ans set up scared me away.
Thoughts?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-26-2006, 07:53 AM
Stressed Member
Scott Clarke's Avatar
Erik-
As long as you can use your existing ring and pinion it might be manageable. Measuring backlash is relatively easy, as long as you know the pinion is set at the correct depth. Setting the bearing preload shouldn't be too big of a deal either. If you are starting without the confidence that the pinion is where it should be, matters become more complicated, as the tool to check the pinion depth is hard to come by. Some people have dealt with backlash and mesh patterns recently. If you do a search you should find some relevant, recent threads. Sorry I can't remember specific titles.
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 07-26-2006, 08:01 AM
Early_S_Man's Avatar
Porsche Crest
Erik,
If it is a factory ZF LSD ... it is identical in dimensions to the existing open differential, so it is a direct bolt-in swap with no required changes to the setup. Plastigauge can be used to verify the current clearance during assembly!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-26-2006, 09:10 AM
defcon65's Avatar
There's a lot of threads on this - Tyson Schmidt has expert advice on this adjustment.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 07-26-2006, 11:30 AM
randywebb's Avatar
Scott, can you define "the pinion is where it should be" more?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-26-2006, 11:33 AM
Stressed Member
Randy-
I mean the fore/aft position of the pinion along the long axis of the car. This is the measurement that requires the special, expensive tool. Without the tool, a protracted series of trial and error trial installations are required (unless you are really lucky).
Old 07-26-2006, 12:15 PM
Elombard's Avatar
Thanks Guys I will have to do some searches, I had not seen it come up.
Old 07-27-2006, 04:00 AM
