Me like track days
Craig 930 RS's Avatar
Exclamation LED lights - a robust solution found for both stop, turn, & brake lights
Incredible selection of superior quality LED lights:
http://www.pmlights.com/products.cfm?cId=1&fId=54
or more specifically
http://www.pmlights.com/products.cfm?cId=1&fId=54&pId=1438#V168A
What I bought:
The beauty of these units is this - you can cut off the end mounting tabs and have a very compact ( 1" X 3/4") unit!
Bought mine at WalMart - $7 each. Sealed, made in Canada.
I plan to use these for stops and front turns for the 930:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-26-2006, 11:16 AM
3 restos WIP = psycho
kenikh's Avatar
I use LEDs built to a standard bulb form factor for my brake lights. They are WAY brighter and turn on faster than conventional bulbs. I highly recommend them.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-26-2006, 11:18 AM
Me like track days
Based upon many prior posts, the challenge has been finding a setup that is bright at all - looks like we've found it -!
Old 06-26-2006, 11:20 AM
Me like track days
These pups are bright! I am really happy with 'em.....
Old 06-26-2006, 12:25 PM
87coupe's Avatar
Good info, thanks Craig & Kenik
ßrandon
Old 06-26-2006, 12:31 PM
Craig:
Marry what you found ( LED)..... together with what I say in the later posts here ( 03-10-2006 09:53 AM posting) of swapping the T/S lights with the side-markers-->
Brake/oil cooling ducts via turn signal lites
... and I think you've got a winner. PM me for details, if you want. I have a further update that uses a portion of the deck grill as screen for the front opening .....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-26-2006, 01:07 PM
Dan in Pasadena's Avatar
Wil, Not sure that link is correct? Just takes you to the general list of Pelican web boards available.
I've never really thought of using LED's but ....how would these units Craig found be used in conjunction with our stock Turn Signal or Running light housings? Somehow they get installed INSIDE of our stock housings?
I can think of some ways it might be done and I think it might work great - though I think it would be labor intensive. Still, might be worth it for safety. They're certainly cheap enough.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 06-26-2006, 01:13 PM
Me like track days
These will tuck right by the leading edge of the side markers (which are turn signals as configured now)
Old 06-26-2006, 01:16 PM
kenikh's Avatar
I have units like this in my car:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8077145126
I love them and they don't burn out.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Driving member
jester911's Avatar
Lets see some pics installed and on. I would love to go to something like that.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 06-26-2006, 01:19 PM
Me like track days
I am buying a set that Kenink listed - Kenik, can you take some pics and give us some impressions?
Old 06-26-2006, 01:47 PM
rfuerst911sc's Avatar
Craig911 were these in the auto or sporting goods dept. at Walmart? I'm interested in these. Thanks
Old 06-26-2006, 01:58 PM
kenikh's Avatar
I will as soon as I can, but my single battery died and am waiting for my Sonnenschein dual battery set up to arrive. I'll have no current until the work gets done. FWIW, I love them. My light buckets are no longer reflective, so the increased light output picks up the slack.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-26-2006, 01:59 PM
Slumlord
Porsche_monkey's Avatar
If your turn signal bulb is not 21 watts it doesn't work properly...
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-26-2006, 02:18 PM
Me like track days
PBH -
Are you referring to the led cluster or the LED orange/red lights?
Old 06-26-2006, 03:30 PM
Senior Member
Good idea!
Old 06-26-2006, 03:38 PM
try my link now...should work....
Wil
Wil Ferch
Old 06-26-2006, 05:09 PM
How are you planning to put these in the rear Craig?
1987 911 sunroof - just starting out on that slippery slope =-D
Old 06-26-2006, 06:38 PM
Me like track days
Auto section of WalMart -
By trimming the tabs off the sides, mounting inside the rear lights should be relatively easy. Securing to the housing may be a bit tricky.
Old 06-26-2006, 07:33 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I am going to try and look for these in white, would make a nice backup light for once I have the 911R lamps mounted. =o)
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-26-2006, 09:26 PM
