LinkBack | Thread Tools | Rate Thread |
Slumlord
If you replace your 21 watt bulbs with 15 watt bulbs (which I did by accident) you will find the flasher circuit doesn't work right. The flasher frequency is wrong, and both turn signals in the dash illuminate. The LED's likely have the same issue. Last edited by Porsche_monkey; 06-27-2006 at 04:58 AM.. |
Me like track days
I'd surmise that the brake lights would be fine - would you?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
3 restos WIP = psycho
Brakes work great. The flashers are said to work fine. The base of the LED bulbs have a circuit board that ensures the correct load and impedance. I am sure you could confirm with any seller.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Slumlord
Maybe they add a resistor to increase the draw, but I don't think 21 watts is NA standard, 15W seems to be the standard now, and they would not work on my car.
I guess we need a guinea pig...
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Me like track days
I'll give them a try when they arrive.......
Me like track days
Since the 930 is sans engine, I won't be testing them in the near future - but they arrived - this is what they look like:
I just got back from Autozone. They have the lights Craig is talking about 2 for $8 ! Way cheaper than the evilbay guy!
T
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Me like track days
Mine *were* about 8 bucks. It's just the 9 bucks screw job shipping that kills ya.....
Hey my trip to Seattle has been pushed out a few weeks. Any chance that beast will be running then ? Todd
Me like track days
I'd say about mid-July - you here then?
Yeah, I should be. Won't be next week, the after at the very earliest and probably the week after. Let's plan on it .
T
Me like track days
Deal. PM me when you are in -
Oooh. I wonder if these will work on the 993. Since I have clear front lenses, I'd need the LED's to be amber. But my Euro tail light lenses should take white LED's. I haffta check the connections and wattage when I get home.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Actually I think I saw them in colors as well at Autozone.
Anyone know off-hand if the 3rd brake light on '86 (mounted high on rear window) will accept this LED clustered bulb base? I'm sure the fitting will work but which direction is the socket facing? The socket would need to be face rearward, in order for these LED's to shine rearward.
thanks
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
Can these bulbs be used for running lights,brake lights and turn signals?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Do we have an answer from any of those that have installed these bulbs?
1984 Targa |
Typical light output from LEDs is pretty much on one axis with lots of light fallout off-axis. The result, decent light output and reception directly in back of a vehicle - not so good off to the sides.
Not sure if any of the links provided this info, but the latest versions of LED brake lamps mount some of the LEDs in the cluster at various angles to compensate for the off-axis light reduction. Sherwood |
Hey fellas
I have a bit of experience here AND I'm an electronics guy by profession, so theoretically I know of what I speak. Below is a view of one rear corner of my '66. ![]() The LEDs came from the local truck stop store. I ordered a set of LED lights with the housings I bought (from MotoMotions--GREAT service and price!!), but I didn't like the LED assemblies that came with. Kinda clunky to me...these on the other hand are the spittin' image of the original Type R setup but with modern performance. They are BRIGHT. Here's my lowdown on the performance/adaptability issue: And the caveat is that my observations are based on an older (1966), relay-based turn signal flasher design. I'll bet, though, that almost all of our car vintages/technologies are close enough that this will apply. With a set of LED lights in the back for both stop and turn, and standard front incandescent assemblies, no resistors, adapter, or anything are needed. You will need a bit of electronics so that the red lights cover both running and brake. Let me know if you want to try this, I'll be happy to show any of you how it works. Turn signal flash rate appears the same and the instrument panel indicators work normally. Add LEDs as the front turn signals (all are now LED--hey, they were 6 bucks, so I bought extra!)) and you need more load on the turn signal flasher. All this means is a 10 watt, 10 Ohm resistor hooks across the wires. I recommend this to anyone willing to fool around with the idea. It works great! Adam912. Out. |
