rfuerst911sc's Avatar
ignition wires-make your own?
I have a 83SC with stock ignition wires, while the car runs good it's a matter of time before the wires will need replacement. Rather than buy new wires I'd like to replace just the cable and reuse the OEM ends. The ends are "screw" type and I measured the O.D. of the wire without braid and it's 7.39mm so is that considered 7mm cable? And what kind of cable do you buy-standard copper or something else? I went to the Kinsborne site and they sell different wire with different ohm resistance how do you know which to buy? I've done a "search" and I know there are good aftermarket wires but I really like the way the OEM ends fit the plugs. So for you guys out there that have done this bring me up to speed please. Thanks
Old 07-02-2006, 10:00 AM
Waiting to see an answer....
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 07-02-2006, 11:14 AM
Good luck finding stranded copper ignition wire.
Old 07-02-2006, 01:47 PM
abit off center
cgarr's Avatar
I made up a set for my lower plugs on my 86 and used some bulk Beru wire with some old stock ends and used new m-3 screw ends, the cost was next to nothing, the big ticket items are the ends (boots) if you dont already have them.
______________________
Craig
G2Performance
Old 07-02-2006, 01:53 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I got the Kingsbornes and I really like them. I kept the OEM Beru's to put on the ends. The set from Kingsborne came pre-assembled, with separators, M3 ends crimped on and heat sheath for about $100. Call the guy at Kingsborne and ask him what you need. He's up to speed, and very accommodating.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-02-2006, 01:54 PM
rnln's Avatar
rfuerst911sc,
I used to do that on another car but not sure what is the required type for our car, if there is any. If you can find a solution, please post.
Thanks.
Fat butt 911, 1987
Old 07-02-2006, 10:43 PM
Wer bremst verliert
JohnJL's Avatar
If you need new boots/ends I've heard there is a Buick part number...seriously.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-03-2006, 02:27 AM
Wer bremst verliert
JohnJL's Avatar
aseem's Avatar
Check out these threads:
Ignition Wires
Plugs and wires
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 07-03-2006, 03:46 AM
Wider is Better
wholberg's Avatar
When I had my '79, I bought a set of Bosch wires and trimmed them for a custom fit, then re-used the Beru connectors. I went as far as threading them through the woven steel sleeves, and that car ran great for the next 2 years, until I sold it.
I don't see any problem with it. I have custom cut ignition wires for several of my cars, and they have all run well afterwards.
Wider is Better
Old 07-03-2006, 04:07 AM
Air Medal or two
afterburn 549's Avatar
Cake walk, go to NAPA . Get marine ign wire (Bulk) Put the old SS stuff on them will work just as good as a 300.00 set. They are solid core so you get the same results.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 07-03-2006, 05:07 PM
I bought a roll of 9mm MSD wire from Summit Racing. Had to shave the insulation down abit to fit into the boots but it works great. Check all your connectors before you finish this job. I had to replace a couple due to high resistance. Normal resistance seems to be about 1K ohms. Got some good used ones from Parts heaven (had to take my ohm meter in though as they don't check the resistance).
-Andy
Old 07-03-2006, 05:46 PM
SCWDP911's Avatar
sub'd
Shane
- 1984 928S
Old 07-27-2007, 05:59 AM
Remember
The Turk's Avatar
I found a guy by the name of Mark Robinson that makes up custom Beru wire sets, apparently he has a set of special crimpers for putting on the ends, you reuse your connectors, he only supplies the wires.
I had him make up a couple of custom coil wires for my 993 distributor twin plug conversion I did, they look like factory, he got them to me within a couple of days and they were very reasonably priced.
Mark Robinson
porschesolutions@gmail.com
www.928turbosports.com
Gary
1975 911S G50 3.5 Twin Turbo
Old 07-27-2007, 10:59 AM
SCWDP911's Avatar
Really!? Man, I bought Kingsborne after doing some research adn they did not last 4 months before the light show started again. Maybe I got a bad set?
Shane
- 1984 928S
Old 07-21-2008, 03:41 PM
rnln's Avatar
I heard/read of light show almost 10 times already. Anyone got picture?
Fat butt 911, 1987
Old 07-22-2008, 09:25 AM
