XLR8'd Member
Disconnecting fan...simple question
I want to isolate a sound I hear from the block and need to disconnect the main fan. Can someone tell me from where I disconnect it? Do I also have to disconnect the AC motor?
David (mechanic wanabe) 2002 Carrera 4S (replacement for an 84 coupe) 06 Acura CSX (wife beater) 05 Acura MDX (toy hauler) http://www.pelicanparts.com/gallery/david_84_911 |
Virginia Rocks!
The fan that cools the engine? The big one? You need to take of the belt.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
XLR8'd Member
Yes the big fan, I simply do not want it to turn while I listen....so I want to cut its power for a minute...
It is turned via the fan belt you see...
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
XLR8'd Member
I see said the blind man to his deaf dog......
Thanks, makes sense....
by the way.....dont let the engine run long without a fan....or you will be hearing really bad noises of fried engine internals...for what it is worth
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
