yes that would be great. I need to learn it. when I get it back together I will query the bitzracingyahoogroups on its set up
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-25-2006, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #241 (permalink)
sorry to hear about this Ben.
I've been quietly following this thread sucking it all in.
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 11-25-2006, 05:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #242 (permalink)
It was a known possibility from the beginning so not the end of the world. Hey it will be a bunch better and safer when finished this time
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-25-2006, 05:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #243 (permalink)
my 3.2 ss/twin plug/turbo motor
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-07-2007, 01:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #244 (permalink)
KCPSG's Avatar
Well after the last few very aggrivating days, I finally got it running this morning...just need to dial my AFR's in and I'm in business.Biggest problem I had was getting my gauges to read correctly and the LC-1 was kind of a pain in the a$$
Thanks Ben
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 01-14-2007, 07:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #245 (permalink)
let me know how you got that lc1 working.. I need to log mine when I get it back working
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-14-2007, 11:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #246 (permalink)
KCPSG's Avatar
I had to hook the computer up to the LC-1 1st and make sure it was reading 14.7 gasoline, then had to do the same thing w/the XD-1 using the LM programmer and again make sure that it was reading 14.7 (gasoline) as the default. then after many many tries I was able to connect the computer to the gauge w/the gauge hooked to the LC-1 and the computer hooked to the (out) 2.5mm connection and connect thru logworks and make a 1st run and record my AFR's.
However I have still not been able to get the "record" button to function as it should,
But for now I am @ least getting something recorded, so I can see where I need to make a few AFR adjustments. Right now I am running really rich as much as 10.35 @ roughly 4k. when the boost starts climbing.
I have a question pending Klaus's response on Innovate's site.
Phil
1998 BMW 328i
Old 01-14-2007, 01:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #247 (permalink)
