Accelerator pedal bushing - replace?
It appears the bushing for my accelerator pedal level has broken. The lever appears straight it just wobbles.
Before I pull it out - can this be replaced w/o pulling the pedal cluster? Certainly looks it to me. Thanks Earl
78 SC Coupe 93 RSA (Gone) |
I suppose it is possible but you will be saving time and grief if you pull the unit out and replace all the bushings.
Look here for the procedure: http://www.pelicanparts.com/techarticles/Mult_pedal_cluster/Mult_pedal_cluster.htm
gary |
Gary,
Thanks , but all the other bushings are OK its was rebuilt by PO. Not sure it would save any time to pull the whole cluster. Thanks
