How fast can you drop an engine (CIS)?
Obviously makes a difference how many you've done. Please comment on that as well.
I'm trying to decide if I should go with a race engine (for the track obviously) and a "street" engine, and if a great deal of time would simply get tied up making the changes. Why? Because I might be headed back to Kali.... Or should I just sink my money into a early 70's tub and be rid of the 930? Suggestions welcome.
Peter '79 930, Odyssey kid carrier, Prius sacrificial lamb Missing 997.1 GT3 RSnil carborundum illegitimi Last edited by artplumber; 07-14-2006 at 08:03 AM.. |
Senior Member
Peter,
After you have done a few, its easy to get one out in an hour or so, especially if there are two of you. Access to an air compressor and some air tools make it a breeze, a lift is even better. Head underneath to get the CV bolts, clutch linkage, throttle cable, speedo wire or cable, heater hoses if installed, ground strap and starter cable and slightly loosen the gearbox bolts. Oil should have been drained and pull the "S" hose. Inside to do the gear shifter link. Top is the fuel line and 14 pin cable as well as the coil wire. Then the two rear mount bolts. Put a jack under it and remove the four mount bolts and its done. What did I forget?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Non Compos Mentis
My first engine drop took about five hours.
The second drop was about two. |
Senior Member
Remembered another thing...
Disconnect the back up light wires off of the gearbox.
Limbo
Out in 1.5 hours and back in and running in around 2.5 hours.
That's after doing 1 or two.....
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
Senior Member
about an hour - Joe don't see you mention shift linkage
78 Euro 911sc Targa 03 Hayden SCWDP |
Somewhat off topic, but I remember reading about a contest years ago where the contestants (2 people per vehicle) had to drive a Volkswagen Beetle 100 ft, drop the engine, re-install the engine and drive an additional 100 ft. Fastest team won.
I think the winners did it in less than 8 minutes. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
2 hours out, 2-4 back in w/o help. faster with help.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
8 minutes, mike?? holy cow..
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Senior Member
I guess I was worried about extra plumbing with the CIS and the smog pump et al. making it a prolonged effort no matter how experienced one was.
Peter '79 930, Odyssey kid carrier, Prius sacrificial lamb Missing 997.1 GT3 RSnil carborundum illegitimi |
I amazed myself by dropping my engine in a little over 1hr by myself!
Jon |
We once timed ourselves. Three guys. Back the car into the garage... start timer...
Crankshaft in our hands... stop timer... 4 hours. Going back together takes significantly more time. :-) Jim |
Virginia Rocks!
There's a group of us here in NoVa/DC/MD. We can do them in less than 2 hours. Things t hat alway seem to be a holdup: getting the transmission nose out of the tunnel and jacking it up just high enough.
It does take longer to go back in... the accelerator linkage was a hold up the last time I did it. It's hard to get the clip on when you can't reach it. The rest just bolted right up. Ask me how long it takes to get out a 944 motor. ![]() For your purposes, I'd just buy another car. It's a pain to just put the track tires on for me.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Unregistered
The thing that takes the longest (for me) is jacking the car up high enough to get the engine to clear.
If I had a lift I could have the engine out in 20 minutes and back in and running in 35. Disclaimer: I've done it a couple of times and used to make a living repairing large industrial machinery for a living, speed (and accuracy) meant profits so I have experience with this sort of stuff. |
I have a friend who used to build modified 911 turbo motors down in Florida. I've pulled a 3.2 Carrera motor with him in just over an hour. His best time? He tells me that with a team of guys familiar with the procedure, lift, air tools, - 17 minutes.
'13 911 C4S Past:'80 911 SC w/ 3.2 conversion |
Virginia Rocks!
I think those very short times quoted mean a couple of things:
- A well running, clean machine, meaning the engine comes in and out regularly. Not the first time since it left the factory. - All tools on hand and no fumbling for the extension sets or the proper size wrench. - A ready supply of consumables (CV bolts, gaskets) and spares for stuff that gets dropped and rolls away.
