I replaced my bulbs and the results were nothing to write home about. I then replaced them with LED's. The results were slightly better. I've read that adding headlight relays can help the dash light circuit but I can't verify that. The trouble with the LED's is that they don't have that 'old school' yellow light look nor do they have the wide spread that the bulbs had. They give off a much whiter light but produce hot spots. The best solution appears to be the big bucks NH speedo conversion but I have never seen what that looks like with the stock black faced gauges. If you do some poking around on the net you will see that the bikers and blingers are using some flexible, low profile LED strips on their vehicles. I'm betting that this is what NH Speedo is doing with the gauges because the flexible string off LED's can be wraped around the gauge case and eliminate the hot spot. I would be interested in seeing how they apply power to the gauge?
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 07-20-2006, 05:03 AM
HELP!
I tried to pull the red looking plug - where the cable goes trough - and could not get it out.
What should I pull straight out, the red plug only or the entire cylinder that holds the red plug?
Old 07-22-2006, 11:39 AM
bump!
Old 07-23-2006, 10:14 AM
Sultan of Sawzall
rouxroux's Avatar
Miguel, be very careful and pry the metal collar up that surrounds the "red plug"...the entire lighting unit will come out easily as one assembly. Best of luck with your project.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 07-23-2006, 10:43 AM
I put in a "Mark Sucro" relay kit when I did the changeover to H4's and that alone significantly increased the candlepower of my instruments. Seems to pass more power through to the lights than through the stalk switch. I'm sure that if I put new bulbs in there, it would also brighten them up. Mine are quite adequate now with the relay kit.
spider911
Old 07-24-2006, 04:55 PM
Chris Lovell's Avatar
I would be interested in how this LED "dash bling" upgrade might be accomplished, and what parts would be needed. It sounds like a decent and meaningful weekend project which will be rewarding.
Any thoughts you electrical gurus?
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 07-25-2006, 05:12 PM
Brando
quattrorunner's Avatar
Slant nose, you have a PM
Turbo powa!
1977 911s. it's cool
Old 07-25-2006, 05:24 PM
holtjv's Avatar
Originally posted by Miguel Antonett
bump!
I used one of those little flathead screwdrivers to get it started, prying under the metal ring. Then I switched to a bigger blade flat head and twisted to get it up. J
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 07-26-2006, 08:31 AM
Early_S_Man's Avatar
Porsche Crest
Guys, if you are having to use tools to pry to get the bulb holders out ... THAT SHOULD BE A BIG CLUE TO YOU that the bulb holders need cleaning and polishing!!! Ask you self WHY they are stuck??? Corrosion, that's why!
Only the alternator warning lamp bulb is the larger #1816 style bulb! All of the illumination bulbs are BA7-base bulbs, 2 Watt.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-26-2006, 08:39 AM
84porsche's Avatar
Send a message via Yahoo to 84porsche
Originally posted by qlander
LED and white faces NH speedo. Expensive but worth it.
BEAUTIFUL - Can you post how much this cost? It might be something worth saving for.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 07-26-2006, 09:25 AM
I think he said $700
Currently own:
1980 911SC slantnose
1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because)
2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD)
Gone but missed:
1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade)
1984 Jeep CJ-7 (1994 Chevy Blazer)
1987 Chevy Corvette (1996 Mustang Cobra)
1993 Jeep Wrangler (1995 Mustang GT Conv.)
2003 Ford Explorer Sport Trac (1987 BMW M6)
Future: Hopefully not too far off
Ferrari Testarossa (Lamboghini Diablo or Countach)
Detomaso Pantera
Old 07-26-2006, 09:27 AM
Porsche Crest
I'm not sure why two guys had to repost the pic of those Horrid white-faced gauges, as those look like they are perfect for (and a copy of) an eBay Gemballa custom-built for some present/former media 'star' with questionable taste and intelligence! Pure, outragious, ricer-style, attention-seeking appearance, and fully capable of completely destroying your night vision! It could only be worse if the illumination was BLUE!
Warren Hall, Jr.
Old 07-26-2006, 11:49 AM
Dan in Pasadena's Avatar
...Not that you have a definite opinion or anything
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 07-26-2006, 11:56 AM
84porsche's Avatar
I am not a fan of the white face but more a fan of the lighting quality. I would be interested to see a better illuminated black face gauge. We already have Porsches, how much more attention seeking would white gauges add. It is a personal preference, some like it, some don't. Speaking of blue, it looks quite cool in a modern day VW so much so that many manufacturers are copying them. - http://forums.vwvortex.com/zerothread?cmd=print&id=2437133
2003 VW Jetta GLI
Old 07-26-2006, 12:02 PM
As an old school sports car fan I have to admit that before I owned my 911 I once owned a 62 twin cam MGA. I always liked the the dimly lit gauges on the MG but I was 21 at the time. When I stepped up to the Porsche I was pleasantly surprised at how modern and bright the 78SC guages were...well, that was back in 85 and I was 37. Same car, same owner but my eyes seem to want more light for just about anything I do these days. If I drove the 911 everyday and more often at night I think I would spring for the NH mod on BLACKFACE gauges. In the meantime I'm still exploring those flexible LED strips. Can any of you guys that have gone down this road post a picture of the rear of the gauge showing the electrical connection?
Peace, Ron
www.ronorlando.net
Old 07-27-2006, 06:54 AM
I'm with you Mysterytrain. I have my car for 25 years and somehow the dash lights are going away... :-)
Old 07-27-2006, 07:03 AM
safe's Avatar
+1
Original poster: You are aware that you can dim the gauge lights by turning the headlight switch?
If not check if it's on max.
Magnus
Old 07-27-2006, 10:45 AM
Zombie
I recently tried this led swap. This is what I ended up with maybe I did something wrong. I think leds need a stronger current to work properly.
The Pragmatist
Old 09-16-2006, 01:30 PM
Zombie
BTW these are the super bright white leds from Super Bright Leds .com.
The Pragmatist
Old 09-16-2006, 01:32 PM
I never investigated LED's as other pelicanheads have so only a wild guess that the special glow paint on the gauges is old and worn?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-17-2006, 04:24 AM
